02-15-2008, 09:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | v3r at&t unlocked via TP with smartmoto[reference] first disassemble phone then check the tp point then connect the usb then attach the tp now once tp attached click search button then wait for the sending boot in smartmoto.now you can remove the tp and wait for the process to finish.then goto unlock tab and use unlock via tp. Logs Here: Code: SmartMoto 3.02 S-Card: Dark_AlfoX Smart-Clip dongle, v 2.01, assigned Smart-Clip: Dark_AlfoX Europe, initializing... OK Clip serial: Dark_AlfoX, version: 4.01, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Clip serial: Dark_AlfoX, version: 4.01, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Clip serial: Dark_AlfoX, version: 4.01, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,W490,W510,Z3 Hardware IMEI: 3577130128alfox IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 3577130128alfox.mbk" Unlocking phone... OK |
The Following User Says Thank You to alfox For This Useful Post: |
Successful Unlocked Via Tp With UB | MobilesDoctor | Universalbox | 50 | 07-29-2010 10:03 |
V3r unlock without tp with gotmoto? | marlenemr | GOT Motorola | 0 | 06-28-2008 20:50 |
V3t T-Mobile bootload A.52 unlocked via tp with smartmoto 3.12 | alfox | Smart-Clip | 8 | 04-04-2008 03:28 |
V3r unlocking via TP?? | alexiej | Motorola P2k | 14 | 10-24-2006 18:10 |
