11-08-2008, 13:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | v3re dead after connect TP SmartMoto 3.18 S-Card: 01111111111111 Smart-Clip dongle, v 2.10, assigned Smart-Clip: /////////////////// Europe, initializing... OK Clip serial: ///////////////// version: 4.08, initializing... OK Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Reading phone boot version... io timeout Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.00 Boot prepare... failed Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK File stream error ("C:\Program Files\GsmServer\SmartMoto\flash files\V3re R3442A_G_0E.43.08R_lp002E_full_flash.mfw") |
11-08-2008, 13:59 | #5 (permalink) | |
Freak Poster Join Date: May 2007 Location: MRU Age: 34
Member: 499093 Status: Offline Thanks Meter: 26 | Quote:
11-08-2008, 14:02 | #6 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
is it damage.... 4.00 boot mean damage hw chek the capaster where you connect tp and resold it if its damage try and post reply | |
11-08-2008, 17:13 | #7 (permalink) | |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
Please ensure the TP zone is clean and the mainboard doesn't have any short circuit. (Help is unable) B.R., kashi4gul | |
11-10-2008, 08:20 | #8 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | if i want to reflash i got this error File stream error , and i have been using this file, is that even the downloaded file expire after one month?, |
11-10-2008, 10:56 | #9 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | The thing is that you are dealing with hw damage. Flashing will not solve the issue. Best Regards GSMServer team |
11-11-2008, 09:51 | #10 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | how to solve this problem, can u view the smart log and tell me what to do, i can say that the phone died during prepration mode |
11-11-2008, 09:58 | #11 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ MGT SOFTWARE, Check the PCB of the phone for any short circuit, because boot version get read as 4.00 in case if the phone has some hardware malfunction, usually. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-26-2008, 13:17 | #13 (permalink) |
Junior Member Join Date: Nov 2005 Location: MX-KEY is the BEST NOKIA TOOL
Member: 201140 Status: Offline Thanks Meter: 0 | I am solve this problem.. hwo like solve this problem send me photo phone hardware and i help you Last edited by GSM_Support; 11-26-2008 at 13:36. |
11-26-2008, 13:38 | #14 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | There can not be a universal solution for this issue. All depends on the reason of the failure. Best Regards GSMServer team |
V3re dead : Damaged tp | zeel_zeel | Smart-Clip | 6 | 06-06-2009 05:40 |
Motorola V3re Dead After Smart Testpoint | lacasapc | Smart-Clip | 10 | 11-14-2008 16:46 |
W490 W510 V3re Dead after unlock attempt | mishaelwillo | Smart-Clip | 34 | 02-22-2008 09:36 |
How to repair K608i who dead after connect TP | gsmobile1 | Cruiser Suite | 0 | 01-14-2006 15:24 |
How to repair K608i who dead after connect TP | gsmobile1 | Cruiser Suite | 0 | 01-14-2006 15:11 |
