v3re help to phione revive and unlock I tried to unlock http://i46.tinypic.com/19hts.jpg now it stucked in blank mode and with smart clip it shows botloader versin 4.0 I did open test point but can not prepare with smart clip how to revive please? |
any help from support yet not given answer please help support team thanks. |
@ kariakala Please check this thread. There you can find your answer. Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
I did checked sir its not shows any short circuit it was stuck on flash mode I try to flash set it stopped cause of power failure and now set is in Sblank mode it would be great it can be connected flash thanks |
@ kariakala As the phone get read as "S Blank" and boot version get read as "4.00" any procedure could not be performed to this set. Flash, Repair PDS or Unlock procedure could not be performed if Argon based phone model get read in such way. The only thing we can say for sure, is that the handset has hardware malfunction that doesn't allow any procedure to be completed successfully. I can recommend you to double check the PCB of the phone, one of possible reasons for such problem could be damaged or shorted TP zone. Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
ok sir I will check it tomorrow and reply you thanks for the answer |
