06-23-2009, 06:34 | #1 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 315550 Status: Offline Thanks Meter: 110 | V3re Pls Help Unlocking Now Dead, but it can detect!!! When i tried the smart TP "prepare Phone" in the TP procedure it found the TP 4.0 many times i tried,.. then my PC hangs... i restarted PC then do it again now this is it,... it says boot version not supported |
06-23-2009, 07:29 | #2 (permalink) |
Member: 315550 Status: Offline Thanks Meter: 110 | The strange is when i check(tester) the board w/o LCD it is shorted but when i connect the board to the flex (assembled it...) and test (on tester) no short~~... any help?!! tia. |
06-23-2009, 13:23 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Your handset is in "Blank mode" which means that more likely it has a hardware damage. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
C60 dead..but I can use FREIA on it! | Jeanne | Siemens Hardware Repair Area | 7 | 10-19-2006 10:31 |
Panasonic GD87 dead but i can flash it | GazI | Panasonic | 7 | 10-29-2003 11:04 |
gd35 for unlock ,,,,,now DEAD, pls HELP | PTR999 | Panasonic | 0 | 10-13-2003 20:55 |
