Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 09-23-2008, 10:40   #1 (permalink)
Member: 655997
v3re unlock error...help
i tried to unlock v3re version oc.f4.. i finished all procedure but when it comes to tp connection always say no phone found,sometimes it connects but detects boot version 4.0 instead of 0.00 then no phone found again..tried many times reconnecting tp but always the same..now the phone is dead..when i insert battery it show bootloader immediately, then shows logo and it powers off..can you help me what to do in order to atleast revive the phone so that customer will not get mad at me..i am using brand new smart tp...any suggestion,,,,....? thnks in advance
Old 09-23-2008, 10:41   #2 (permalink)
aiyon_861's Avatar
Member: 586707
check if your TP is connected or your tp is workinf good....
The Following User Says Thank You to aiyon_861 For This Useful Post:
Old 09-23-2008, 10:45   #3 (permalink)
Member: 655997
i thinks its good..anyway can yu help me how to test if my smart tp is working...or not..thnks
how can i peform testpoint again if the phone does not power..thnks
Old 09-23-2008, 10:58   #4 (permalink)
rico_deep's Avatar
Member: 159757
Put your phone on BOOTMODE and UNLOCK it again via Prepare Phone.
The Following User Says Thank You to rico_deep For This Useful Post:
Old 09-23-2008, 11:20   #5 (permalink)
gujjar_brothers's Avatar
Member: 558087
Sonork: 100.1579413
again prepare phone & connect ok testpoint & write backup ,
The Following User Says Thank You to gujjar_brothers For This Useful Post:
Old 09-23-2008, 11:28   #6 (permalink)
aiyon_861's Avatar
Member: 586707
first check your TP or use smart TP version 2...then press power on then unlock via smart TP then wait for the next instruction of your clip.....
Old 09-24-2008, 10:32   #7 (permalink)
Member: 655997
IM USING latest smart moto and tpv2...
the phone was recognized but it fails in the last second
Searching for phone... found S Flash Neptune LTE2
Switching to flash mode... OK
Reading phone boot version... 0.00
Reading flash id... ST - M58LR256A
Phone group: V3re,K1/s
Hardware IMEI: 3524760xxxxxxx
IMEI OTP status: locked
Security area saved to "PDS for S Flash Neptune LTE2 352476020831299.mbk"
Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_79018F4C145D8010.bk_
Restore OK
Unlocking phone...
error 9B
after how many tries it boot again but with different error..
Hardware IMEI: 352476xxxxxxx
Security area saved to "PDS for S Flash Neptune LTE2 352476020831299 (1).mbk"
Restore OK
Unlocking phone...
error A0
any suggestion..thanks
Old 09-24-2008, 13:02   #8 (permalink)
GSM_Support's Avatar
Member: 121052
More likely your phone has a hardware issue.
Best Regards
GSMServer team
Old 09-24-2008, 14:32   #9 (permalink)
Member: 203747
Thumbs up hi
keep the TP conncted to the end of all i think
Old 09-24-2008, 14:56   #10 (permalink)
Member: 121052
I don't think it will work, but anyway you can try.
Best Regards
GSMServer team
Old 09-25-2008, 01:47   #11 (permalink)
Member: 859810
hello
u must remove tp faster and press ok faster olso not take many time when program tell remove tp
try im sure will phone unlock done
br
Old 09-25-2008, 03:16   #12 (permalink)
Member: 655997
Best Regards
GSMServer team
is there any way to revive this phone because the phone dont power after the last error....
Old 09-26-2008, 07:44   #13 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
@ kevin182029,
In case if the set can not be powered on at all, then it definitely has some hardware malfunction.
Please check the PCB of the handset.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 09-27-2008, 13:58   #14 (permalink)
Member: 587422
i need v3re test point plz my email is mazharbbr@gmail.com
Old 09-29-2008, 07:44   #15 (permalink)
Member: 229997
@ mazharbbr,
All TP pictures can be found at the www.boot-loader.com in the Public Downloads->testpoints->... section.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
plzzz help V3re Unlock error ikkks Smart-Clip 5 06-26-2009 06:09
V3re Unlock Error 9b wiliam Smart-Clip 11 06-01-2009 08:04
v3re unlock error 9B ajaycrunch007 Smart-Clip 2 10-18-2008 09:39
v3re unlock..error 9b zeozea Smart-Clip 3 02-06-2008 09:48
v3re unlock error help me please!!! pasakalye Smart-Clip 2 11-27-2007 11:03
Page generated in 0.82638 seconds with 11 queries
