11-20-2008, 06:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: places I repair phones
Member: 621698 Status: Offline Thanks Meter: 405 | V3t and K1 after unlocked w/ smartclip, mp3 features doesn't working |
11-20-2008, 08:39 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | That sounds really strange. We never had this kind of trouble. Also, i can ensure you that unlock process can not affect MP3 functions. Are you sure that the handset didn't have a trouble with MP3 playback before unlock? As a solution, i can suggest you the following. Try performing Master Reset and Master Clear. As far as i remember, when setting the ringtone from the memory card, the music file gets copied into the phone's memory. And it may happen that phone's memory is already full, that's why the file can not be copied and used as a ringtone. Please double check and let us know. Best Regards GSMServer team Last edited by GSM_Support; 11-20-2008 at 08:44. |
11-20-2008, 11:52 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | What is your phone's current firmware version? I can advice you to flash the latest firmware for your region and to see what happens with setting ringtones. |
11-21-2008, 10:19 | #4 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Mymiela0419, In order to be able to set mp3 as a ring tone you must remember the following: 1) Save necessary *.mp3 files at a flash card OR in a phone's memory. 2) It is possible to set mp3 as a ring tone when contact is stored in phone's memory only, not in sim-card. If you want to move contact from Sim-Card to Phone's memory, press View -> Edit -> Store to -> Phone -> Done. Now you will be able to access some additional menu points, like "Additional info", "Adress", "Ringer ID", "Picture" and more. 3) If contact is stored in the phone, then Press View -> Edit -> Ringer ID -> Change -> select necessary *.mp3 ring tone from the list of available ring tones -> Press "Select" -> And don't forget to press "DONE". Congratulations! You're now able to use mp3 features in phone book! And it's clear that unlock process can not affect MP3 functions |
bb5king "no tp" feature doesn't work? | flydog | BB5KING for (BB5BOX) | 16 | 11-30-2008 05:47 |
mp3 player doesn't work with x65 above v.14. | Mihauek | S-Gold Based Phones | 4 | 02-25-2005 18:26 |
V220 from Canada after unlock with Smartclip no ring tones | dominik | Motorola P2k | 1 | 12-19-2004 09:20 |
Where do I buy a cable that works for unlocking? I have one that doesn't work... | laxxe | Alcatel & TCL Old Models | 0 | 09-12-2001 20:39 |
unlock c1 by Yagoda imei doesn't work | alro | Sony | 6 | 05-04-2001 08:37 |
