12-23-2008, 22:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Palestine Age: 40
Member: 26041 Status: Offline Thanks Meter: 160 | V3v Stuck on Boot Loader after unlock Any solution ? I have V3v with Boot loader A.52 firmware verison R4515_G_08.BD.B3R I tried to unlock it using TP it failed , sorry i didnt save the log I tried to repaired PDS then full flash with the same firmware here log in the first time i repired pds use tp and boot loader become A.30 ,so i use prepare cycle to do the repair. Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 354781011265052 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 354781xxxxx (2).mbk" Now you can perform Repair PDS or Unlock operations. To get phone to work, you should write flash into the phone Login request... OK Writing flash section 2 of 2... 100% (31.3 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (13.2 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (45.2 Kb/sec) Flash completed! problem still , i downloaded latest firmware R4515_G_08.BD.F9I_LP002E_DRM0101_SE6834AXXU1141_1F F_RoHS_Russia_Retail.pcf and flashed it via Scout also problem still what i do to solve the problem ??? Best Regards. |
12-24-2008, 03:13 | #2 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Mars
Member: 87284 Status: Offline Thanks Meter: 23 | well i had a similar problem with a v3xx it got stuck in the boot version screen, and sometimes i couldnt even turn the phone on, the problem was that i accidentally did a little damage in the resistors when i cut the metal, check em very carefully, i dont know if you need to cut any metal from that model but if you do check them and replace them and if still doesnt work after replace, reflash again, will work 100% |
12-24-2008, 08:04 | #3 (permalink) | |
Member: 26041 Status: Offline Thanks Meter: 160 | Quote:
i use small tp not wire , i didnt Damaged any resistor . I reflash phone 3 times problem still . thanks | |
12-24-2008, 11:36 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | If you could show us the log file form the unlock attempt, where the error appeared, then it would be easier for us to find the solution. Now it's hard to suggest what exactly could be done. More likely the phone got the damage during TP procedure. But without log with error it's hard to say what exactly went wrong. Best Regards GSMServer team Last edited by GSM_Support; 12-24-2008 at 11:55. |
12-25-2008, 08:47 | #5 (permalink) | |
What happened to me , i will desripe hope u helped me . i use tp to unlock this phone and after press UNLOCK VIA TP program wrote Reading phone boot version... A.52 Sending boot... fail i repete the procedure also the same error , i assembled the phone to see if phone still work after this error , when i put battery phone enter boot loader . today i used tp by connect wire to GND , repaire pds + full flash > same problem . what i do to solve the problem ? Best regards. | |
12-25-2008, 08:51 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | What version of full_flash.mfw did you use after repairing PDS? Possibly you can try flashing it again with the highest available full flash and right after that apply IMEI patch. If that doesn't solve the issue - the phone has a hardware problems. Best Regards GSMServer team Last edited by GSM_Support; 12-25-2008 at 09:27. |
12-25-2008, 09:59 | #7 (permalink) | |
I used the same firmware which the phone had . V3r_R4515_G_08.BD.B3R_lp0039_full_flash.mfw. the phone was new from Vodafone . I will try to do wht u said . thanks | |
3gs 3.1.3 with custom hangs on boot logo after unlock | M_ABRISHAMI | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 02-10-2010 08:01 |
E1000 stuck on boot-loader while try to change LNG | llcoolr | Smart-Clip | 1 | 10-12-2009 21:28 |
v980 - c975 - stuck on boot mode after flash - fianal solution | cel_phon | Smart-Clip | 0 | 07-28-2009 08:21 |
L6 Stuck on Bootloder Mode after Unlock | nomangsm | Smart-Clip | 11 | 10-22-2006 17:05 |
