07-19-2008, 23:07 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Croatia Age: 42
Member: 144433 Status: Offline Thanks Meter: 49 | V3x dead, all repairs failed I tried writing bootloader, but phone dead. I tried every combination I can imagine to make this phone alive, but no success. I'm probably missing something in procedure. I also tried "Force simple write mode" and "Overwrite boot area" I've even tried to flash it with Scout, which recognized phone as: S Flash Rainbow POG R25221LD_U_85.83.84P USRAZRV3XH3GITR2522106D Flash I used is RAZRV3x_R252211LD_U_85.9B.C0R_lp002F_full_flash.mf w, and I tried several other for Scout: R252211LD_U_85.98.E0R R252211LD-AS_U_85.9A.D2P please, any advice would be great.. here is the log: Code: SmartMoto 3.15 S-Card: *********xx Smart-Clip dongle, v 2.09, assigned Smart-Clip: ********* Europe, initializing... OK Clip serial: ******xx, version: 4.08, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.71 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 358*********x IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 358*********x (47).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Login request... OK Writing flash section 2 of 2... 100% (90.4 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (24 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (44.5 Kb/sec) Turning phone off... OK Flash completed! |
The Following User Says Thank You to Inovator For This Useful Post: |
07-21-2008, 08:36 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try the following trick. 1. Perform Repair PDS via Prepare Cycle. 2. Flash the phone with R25221LD_U_85.83.84P.mfw. 3. Right after flashing, don't disconnect the phone and perform IMEI repair patch. 4. The handset should to turn ON afterwards. If it does - restore the original IMEI using SmartMoto. PS. The specified above procedure may not work if the phone has a hardware problems. Best Regards GSMServer team |
07-21-2008, 23:55 | #4 (permalink) |
Member: 144433 Status: Offline Thanks Meter: 49 | tried 2 methods First: 1. Perform Repair PDS via Prepare Cycle. 2. Flash the phone with R25221LD_U_85.83.84P.mfw. (overwrite boot area clicked, all other options not) 3. Right after flashing, don't disconnect the phone and perform IMEI repair patch. 4. The handset should to turn ON afterwards. log: Code: SmartMoto 3.15 S-Card: --------- Smart-Clip dongle, v 2.09, assigned Smart-Clip: ---------- Europe, initializing... OK Clip serial: ---------, version: 4.08, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.84 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 3-------------- IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG -------------- (78).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Login request... OK Writing flash section 2 of 2... 100% (91.7 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (23.7 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 2 of 2... 100% (109 Kb/sec) Flash completed! Writing flash section 2 of 2... 100% (28.8 Kb/sec) Applying IMEI patch, please wait (up to 2 minutes!)... OK IMEI patch successfull, set new IMEI with the "Write" button second method: 1. Perform Repair PDS via Prepare Cycle. 2. Flash the phone with 0.6.8.2 boot, then R25221LD_U_85.83.84P.mfw. 3. performed IMEI repair patch. 4. The handset should to turn ON afterwards. 5. wrote back original IMEI log: Code: Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.84 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: ----------------- IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG -------------- (79).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone Login request... OK Writing flash section 2 of 2... 100% (90.4 Kb/sec) Restarting phone... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK IMEI OTP status: locked Repair PDS request... OK Performing PDS repair... OK Writing flash section 1 of 1... 100% (22.9 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing flash section 1 of 1... 100% (43.1 Kb/sec) Flash completed! Writing flash section 2 of 2... 100% (98.4 Kb/sec) Flash completed! Writing flash section 2 of 2... 100% (28.7 Kb/sec) Applying IMEI patch, please wait (up to 2 minutes!)... OK IMEI patch successfull, set new IMEI with the "Write" button Writing new IMEI ---------------... OK Turning phone off... OK battery is full, off course |
07-22-2008, 08:38 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | For a start, please check this out. Secondly, do you know what has initially happened to your phone, so it got to this state? Are you sure that it doesn't have a hardware problems? Best Regards GSMServer team |
07-23-2008, 09:22 | #7 (permalink) | ||
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Quote:
Also, please give the answers to the following questions. Quote:
You can also try the procedure, specified in the post #2. Just use different flash files. First try with R252211LD_U_85.9B.E6P.mfw. If that doesn't help, please try R25227LD_U_86.31.34P.mfw. Best Regards GSMServer team Last edited by GSM_Support; 07-23-2008 at 09:29. | ||
The Following User Says Thank You to GSM_Support For This Useful Post: |
07-24-2008, 09:37 | #11 (permalink) | |
No need to do it. That option has to be used in rare cases. The boot gets replaced with PDS repair procedure. Best Regards GSMServer team | |
V3x No power... pds repair failed | ASHRIFF | Smart-Clip | 1 | 12-21-2009 08:47 |
v3x dead how to repair pls answer | ttkul | Ultima Box Light | 5 | 10-16-2007 02:02 |
v3x when prepare phone fails now cannot connect with sm | mccm | Smart-Clip | 1 | 03-01-2007 06:16 |
RAZR V3x Smart Moto Unlock Fail | justmegt | Smart-Clip | 3 | 07-27-2006 10:24 |
v3x unlocking always boot fail | mccm | Smart-Clip | 10 | 05-21-2006 09:20 |
