01-25-2006, 15:40 | #1 (permalink) |
Crazy Poster Join Date: Apr 2005 Age: 43
Member: 134726 Status: Offline Thanks Meter: 3 | v3x no display later tp thanks |
01-25-2006, 17:01 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Location: at home
Member: 56735 Status: Offline Thanks Meter: 35 | have same probleme nodisplay after unlock succefull have this probleme with 2 phones, but 5 phones unlocked ok and display ok what solution please there are no flash file in support |
01-25-2006, 20:37 | #3 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Somewhere only we know Age: 42
Member: 102326 Status: Offline Thanks Meter: 0 | Please remember! During testpoint unlocking procedure phone's LCD must be disconnected. Do not use hot air fan to remove a metal shield on PCB. This can seriously damage the handset. Use any other alternative tool to cut or drill it. Please make sure you do not damage the board. |
01-26-2006, 11:01 | #8 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please make sure that Testpoint resistor (33 Ohm) did not get damaged. It's responsible for display functions. Also, was the LCD disconnected during testpoint unlock process? Best Regards Smart-Clip Team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by GSM_Support; 02-21-2006 at 16:20. |
01-26-2006, 16:48 | #11 (permalink) |
Insane Poster Join Date: Sep 2005 Location: senegal Age: 43
Member: 178888 Status: Offline Thanks Meter: 0 | salut tout le monde .je viens juste de trouver la solution pour les v3x ki ont les ecrans qui affiche du noir.pour plus de renseignements contacter moi sur [email protected] |
01-26-2006, 18:46 | #12 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | i think your problem may be down to the way you opened the phone, rather than the procedure itself. the connectors for joining ribbon to board are very much same in this v3x as in sony ericssons... if you just "pulled" the connector apart, you may have pushed one or more pins inside the block so they are not making a contact. check all connector blocks for this. if you find a pin pushed in, you can use a small/sharp instrument (sewing pin) to ease the pin back into view. in future, try to lift all connectors in this type by both ends at same time. and be gentle |
motorola v3x no display after unlock | titol | Motorola Hardware Repair | 23 | 04-01-2009 12:15 |
V3x no displaye after remove phone code by flasing | leroi | Smart-Clip | 11 | 04-04-2008 10:53 |
v3x no display liquid damage | farry | Motorola Hardware Repair | 2 | 12-26-2006 19:24 |
V3x - No Display After Unlock | helplease | Motorola P2k | 20 | 09-19-2006 22:18 |
V3x no Display, only in testmode... | huzsolt | Motorola P2k | 8 | 04-26-2006 14:37 |
