05-04-2006, 15:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: nowhere... Age: 45
Member: 18729 Status: Offline Thanks Meter: 3 | V3x problem 3 pcs of them went successfully over the unlock process, but another 3... They cannot power on. I tried repair PDS, and full flash, tried to write back the first security backup, but no success, nothing. What could I do with them in this failure? Thanks,RGRDS: Ceru SmartMoto 1.19 Clip serial: 20134xxxx, version: 2.24, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 35800300788xxxx Security area saved to "S Blank Rainbow POG 35800300788xxxx.pds" Unlocking phone... OK Clip serial: 20134xxxx, version: 2.24, initializing... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... io timeout Reading phone boot version... io timeout Clip serial: 20134xxxx, version: 2.24, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 35800300788xxxx Security area saved to "S Blank Rainbow POG 35800300788xxxx (1).pds" Writing security area... done Turning phone off... OK Last edited by ceru; 05-05-2006 at 10:05. |
05-04-2006, 15:25 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello ceru, The phone don't Power on at all, or only display not work? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-04-2006, 15:45 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ ceru, when You are making Test Point, Smart-Moto see the phone? what Smart-Moto write? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2006, 10:05 | #5 (permalink) |
Member: 18729 Status: Offline Thanks Meter: 3 | It can read everything as fine, made fubu now SmartMoto 1.19 Clip serial: 20134xxxx, version: 2.24 SmartMoto license saved Clip serial: 20134xxxx, version: 2.24, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 35800300788xxxx Security area saved to "S Blank Rainbow POG 35800300788xxxx.pds" Reading flash 5AB000/4000000... 8% 28.8 Kb/sec |
05-05-2006, 12:27 | #6 (permalink) |
Junior Member Join Date: Dec 2005
Member: 214755 Status: Offline Thanks Meter: 0 | So, I have the same problem.... 1 piece have no display, but the phone is on and i can use it, only black display.And I have second one dead... when I power on only keybord light is on for few second and after I can do anything... I have unlocked them with smarmoto and smartclip, using the testpoint procedure.... and i have result with no error.... bah.... i have no idea.... anybody can help me.... |
05-05-2006, 14:36 | #7 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | For the unit that have no display more likely you have damaged a Testpoint resistor, which is responsible for display functions. Check the resistor, it suppose to have 33 Ohm. For the other one, please try repairing PDS & full flash. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2006, 19:56 | #8 (permalink) |
Member: 214755 Status: Offline Thanks Meter: 0 | For GSM Support..... THANKS A LOT!!!!! I replace the testpoint resistor and the unit revive!!! It's very strange that resistor was broken, because I used 15W iron and microscope to check my work..... So, I suppose I need to buy a lot of 33 Ohm SMD resistor !!! Thank you very much.... So, for everybody if your V3x is dead after testpoint procedure, check the resistor.... is very delicate!!! |
05-16-2006, 01:23 | #9 (permalink) | |
Freak Poster Join Date: Nov 2003 Location: Australia
Member: 44593 Status: Offline Thanks Meter: 7 | v3x Quote:
I did unlocked V3x with smart moto and smart clip it works but the only problem with that is . I dammaged the resistor 33 Oms now i shorted that 2 pin together.. the LCD display now working fine at the moment but i'm not sure that if any thing will be effect if i short that 2 pin resistor together later all??? thanx alll guysssssss | |
05-17-2006, 11:29 | #10 (permalink) |
Member: 214755 Status: Offline Thanks Meter: 0 | x etscellular so, I suppose the testpoint resistor is a pull-up resistor to tie to vcc the IC pin. And I think is better to install a resistor max 100 Ohm to limit the pull-up current. Bye Bye |
05-17-2006, 15:18 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | Hello sayas, Please try to make Repair PDS and after that Full Flash the phone! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
V3x Problem after flasing | lincscomms | Motorola P2k | 1 | 10-28-2007 12:46 |
V3x Problem | Nadeem97 | Motorola P2k | 9 | 09-13-2006 17:26 |
v3x problem | Hell_Spawn_ | Smart-Clip | 1 | 04-18-2006 13:01 |
V3X Problems with MMS, GRPS after unlocking | James-R | Smart-Clip | 3 | 02-06-2006 01:08 |
v3x ...problem to unlock with SC | kidgsm | Smart-Clip | 1 | 01-24-2006 12:10 |
