11-28-2007, 22:08 | #17 (permalink) |
Freak Poster Join Date: Sep 2006 Location: forget
Member: 348988 Status: Offline Thanks Meter: 6 | very simple with original cable from gsmserver is not neccessary to prepare phone before you disassamble it. PROCEDURE 1. DISASSAMBLE PHONE 2. CONNECT USB CABLE VIA SMART CLIP 3.CONNECT SMART TESTPOINT CABLE.(ORIGINAL FROM GSMSERVER.COM) 4.CONECT HOOK TO FON TERMINAL (+). FON POWERS ON. NOT IN TEST MODE THEREFORE CLEAN BACKUP WILL BE MADE. 5.SEACH FON 6.PREPARE FON 7.FOLLOW SIMPLE INSTRUCTION ON SCREEN. 8. SMILE HINTS MAKE SURE TESTPOINT NEEDLE IS ALWAYS FREE FROM CORROSION GET THE EXACT TP POSITION |
12-27-2007, 10:32 | #19 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Inside Age: 47
Member: 71892 Status: Offline Thanks Meter: 13 | @ ~mr_Ten$ion~ How did you solve it? Same problem here. v3xx boot 3.02 stuck in boot mode SmartMoto 3.01 S-Card: 2416xxxxx Smart-Clip dongle, v 2.00, assigned Smart-Clip: 9034xxxxx Europe, initializing... OK Clip serial: 9034xxxxx, version: 4.00, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK failed error 80 Processing data, 6 of 6 block...OK |
12-27-2007, 10:42 | #20 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ free4us, To be able to flash the phone with *.mfw files Prepare Smart TestPoint using Smart TestPoint cable has to be performed. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-27-2007, 11:51 | #22 (permalink) |
Member: 71892 Status: Offline Thanks Meter: 13 | Problem Solved. error 80 Processing data, 6 of 6 block...OK Problem was because of: LOW BATTERY even when the phone display Battery OK Keep that in mind for future No need to flash it, just recharge battery full and make Smart Testpoint procedure. SmartMoto 3.01 S-Card: xxxxxxxxxx Smart-Clip dongle, v 2.00, assigned Smart-Clip: xxxxxxxxxx Europe, initializing... OK Connect phone to Smart-Clip before proceeding Clip serial: xxxxxxxxxx, version: 4.00, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 35408201xxxxxx IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 35408201xxxxxx.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_19A3191844B6C851.bk_ Restore OK Unlocking phone... OK |
01-20-2008, 15:52 | #23 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 54
Member: 80073 Status: Offline Thanks Meter: 5 | "free4us" so your phone was stuck in test mode how did you solve it by using full battery, did you not have too flash it. i also bought cable from GPG and have same problem. how could you apply the test point with a full batt, did you not had to use the smart testpoint cable |
V3xx Preparing...fail cant unlock | Vansy | Smart-Clip | 6 | 07-08-2009 09:38 |
problem with a v3xx 3.02 | pocho30 | Smart-Clip | 7 | 03-29-2008 10:03 |
5300B SEC ***X ATD 3.50 and 5.02 CANT UNLOCK! | gsm8g | J.A.F. V-SPEC | 2 | 03-11-2008 13:32 |
5300 v5.02 cant unlock | mishaelwillo | BB5BOX | 3 | 11-13-2007 06:17 |
V3xx boot3.02 cingular unlock not ok????? | start307 | Smart-Clip | 1 | 09-23-2007 23:56 |
