Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 10-10-2007, 21:16   #1 (permalink)
Member: 81931
Thanks Meter: 92
V3xx cannot power On , DIED
In my hand i have many set of V3xx cannot power On , DIED
No BOOTLOADER MODE
PLUG into PC , will reconize UNKNOWN USB ...
power on with power supply , will goes to 10mah - 0
all is BRAND NEW PHONE and was using for 3 - 4 weeks...
there are no water damage , no drop .
Some of that i already try to CHANGE POWER IC , reball CPU + FLASH = still remaining the same problem ....
ANybody know whats the problem ?
Old 10-11-2007, 07:49   #2 (permalink)
mcandre's Avatar
Member: 239548
Thanks Meter: 2,781
I have few phones, two of them are brand new V6maxx, and I have faced the same problem with them.
I can't find the reason why it happened with them.
Are there anybody here who know any solution regarding this issue?
Old 10-16-2007, 05:50   #3 (permalink)
Member: 81931
Thanks Meter: 92
still no any solution about that
Old 10-16-2007, 07:10   #4 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
No Solution Yet becoz TP for Dead Phone Detection (as was used in previous Phones) is not in aragon base phones...
Ive got 2 pieces as well v3xx....waiting
Old 10-24-2007, 20:00   #5 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
Hi.
Any news to recovery dead V3xx ???
I try using only Smart Clip TP cable, but without sucess.
Old 10-24-2007, 20:04   #6 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
The same problem when repair phone,
May bi SC team is fix this error.
Best and regards
Old 10-26-2007, 06:37   #7 (permalink)
Member: 81931
Thanks Meter: 92
weird CPU problem ..... need to exchange CPU + FLASH ic...
tested...
Old 01-14-2008, 03:17   #8 (permalink)
Member: 110414
Thanks Meter: 5
I have 4 pcs of 3xx all dead just automatically shuting down no boot mode any solution
Old 01-14-2008, 08:07   #9 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ speedtech,
Can your phone be detected by SmartMoto? If yes, run Prepare Smart TestPoint procedure and Full Flash the handset after that. Don't forget to use the same firmware version like the handset originally had or higher one.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 10-08-2009, 04:24   #10 (permalink)
Member: 683456
Thanks Meter: 10
dont buy v3xx.............................................. ..........
....br
Old 11-26-2009, 15:14   #11 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
brother change ur battery 100% ok
Old 06-23-2011, 13:22   #12 (permalink)
Member: 183834
Thanks Meter: 6
only change CPU and Flash, no software workaround ?
Old 06-23-2011, 13:50   #13 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
@ testpoint,
Explain in more details what problem you have, please.
Best Regards
GSMServer team
Old 07-01-2011, 16:53   #14 (permalink)
Member: 183834
Thanks Meter: 6
Originally Posted by GSM_Support View Post
@ testpoint,
Best Regards
GSMServer team
4 V3xx, quite new, Optimus Portugal software, all of them can not boot up, when press the power button, to 200mA current then dropped to zero, can not power up.
Old 07-02-2011, 08:51   #15 (permalink)
Member: 121052
Sonork: 100.107126
@ testpoint,
It shows that the set definitely has some hardware malfunction.
Check the PCB of the phone for any short circuits or other malfunctions.
Best Regards
GSMServer team
v3xx just power on boot mode GSMJordan Motorola ODM 2 01-05-2010 08:59
Please Can Anybody Help, W850i Wont Power On, Died after trying a software update JAMESMARSH1980 Sony Ericsson Hardware Repair 3 09-17-2009 17:40
v3xx not power on insert only batterry alb97 Motorola Hardware Repair 1 09-02-2009 01:25
V3xx Not Powering On jaime1182 Motorola Hardware Repair 3 07-31-2008 07:20
Can flash cannot Power on! Mikimiao Nokia Hardware & Hardware Repair 2 09-01-2002 08:06
Page generated in 0.27945 seconds with 9 queries
