Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 06-05-2008, 00:05   #1 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
Thumbs down V3i D&G stuck in bootloader ....
hi all
after searched all threads and tried everything possible as discussed
repair PDS, FULL flash the set is stil lstuck in bootloader. Tried both with prepare and with TP.
version is R479_G_08.B4.34R. Flashed it with V3i_R479_G_08.B4.85R_lp0039_full_flash and still the same. Used a ******* flash of the exact version R479_G_08.B4.34R and no change
what else can i do pls?
thanks
Old 06-05-2008, 03:08   #2 (permalink)
Member: 149256
Thanks Meter: 285
Here's my way for this problem :
1. repair PDS (make TP ofcouse)
2. flash phone with R479_G_08.B4.8BR_lp0021_full_flash.mfw
3. patch Imei
4. restore Imei
That's all I hope this procedure may help you.
Old 06-05-2008, 04:38   #3 (permalink)
Member: 563980
Perfect File That U Need
SEARCH AND DOWNLOAD THIS FILE AND UR GOOD AND READY AGAIN R479_G_08.B5.76R_PDS006_LP0033_DRM0101_VSTUK_ENGLI SH206_JPJAVA_G_08_V3i_03_00R_GSPSLQAT678GH1A8_1FF. sbf
Old 06-05-2008, 07:41   #4 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ Burnt Cobba,
Please tell us what problem the phone originally had.
Try to Full Flash the phone with the highest available firmware version for this platform, R479_G_08.B5.86R.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 06-05-2008, 07:55   #5 (permalink)
bestncheap's Avatar
Member: 19785
Thanks Meter: 1,242
try use this file
R479_G_08.B5.76R_PDS006_LP0003_DRM0101_VSTAM_SPANI SH206BR_PORTUGUESE206US_ENGLISH206_JPJAVA_G_08_V3i _01_01_04R_GSPSLQA1DGMSTVZLA17A_1FF[Movistar Venezuela UI ***** & Gabanna].pcf flashing with scout..
Your phone will life again in ***** gabana..
or at least use firmware with version R479_G_08.B5.***R
use B5 Full flash firmware
BNC
Old 06-05-2008, 18:27   #6 (permalink)
Member: 11325
Thanks Meter: 266
flashed it with a .B5 firmware and yet it still shows the previous firmware.
Old 06-05-2008, 20:26   #7 (permalink)
Member: 11325
Thanks Meter: 266
funnily enough just got a V3r with same problem but fixed it without a problem. No idea wtf is wrong with this one.
Old 06-05-2008, 20:35   #8 (permalink)
Member: 543112
Thanks Meter: 7
do you have ubl this tool will help greatly for this problem
Old 06-05-2008, 20:58   #9 (permalink)
Member: 11325
Thanks Meter: 266
what can ubl do that sc cant? to be honest i believe sc is the best out there
Old 06-06-2008, 04:17   #10 (permalink)
Member: 481823
UBL??? that's THE WORST TOOL FOR MOTOROLA
THE BEST --> Smart Clip
Old 06-06-2008, 05:58   #11 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
LOL
don't spam the board.
Old 06-06-2008, 07:53   #12 (permalink)
Member: 229997
Thanks Meter: 636
@ Burnt Cobba,
More likely that the phone was flasher with wrong platform flash file.
Due to this reason it stays in boot mode.
You can try to perform the following:
1. Make Repair PDS for R479 platform
2. Flash the phone with R479 firmware version (the highest one, R479_G_08.B5.86R)
3. Perform IMEI patch.
4. Restore ORIGINAL IMEI using SmartMoto Restore IMEI option.
NOTE: Phone cable should not be disconnected during the whole process until the last step is performed.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post:
Old 06-06-2008, 13:27   #13 (permalink)
Member: 11325
Thanks Meter: 266
@MrTinkertrain
First of all thanks a lot for your continous help. Secondly in one of your replies in similar threads you wrote that the flash chip might have to be replaced. Is this the case? or was it in other times?
The last step of the imei if imei is still correct (as i tried to unlock and it seems to be ok) is this always needed anyway?
Thanks
Old 06-06-2008, 13:43   #14 (permalink)
Member: 229997
Thanks Meter: 636
@ Burnt Cobba,
Try to perform procedures mentioned in this post.
Restore IMEI procedure has to be performed.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
motorola v3i stuck in bootloader RUBEL SINGH Smart-Clip 8 09-14-2016 07:53
v3i stuck in bootloader! accepttheownage GOT Motorola 0 08-18-2008 22:23
v3i D&G stuck in bootloader mode help needed amit_varietymob Motorola P2k 3 08-08-2008 17:05
V3i stuck in Bootload mode helplease Motorola P2k 10 06-27-2007 04:28
Please help , my V3i stuck in bootloader !!!! nova75c Smart-Clip 9 06-13-2007 22:50
Page generated in 0.25044 seconds with 9 queries
