12-07-2009, 21:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: TEKNOZER of TURKEY Age: 48
Member: 32738 Status: Offline Thanks Meter: 32 | v3xx r26111ld cant repair after unlock Clip serial: ***********, version: 5.00, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 io timeout Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... no phone found Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 354082010080760 IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 354082010080760 (4).mbk" Unlocking phone... OK To get phone to work, you should write flash into the phone [177] retrying block write at 0xA3EE0000... error BE i flashed this file V3xx_R26111LD_U_96.80.59R_lp0039_USIZRGBLRTESR2611 1035_full_flash.mfw what can i do my v3xx always blank screen |
12-08-2009, 01:27 | #2 (permalink) |
Freak Poster Join Date: Jul 2006 Location: FIND ME!
Member: 306391 Status: Offline Thanks Meter: 21 | ok i will give you any option but i will send you the flash file tomorow wat you will need just the s=cart for smart moto and mini usb cable the the of course the software scout software think u know it then i will give u the flash file ok remmain me |
12-08-2009, 08:24 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ ozeracar, Please ensure that the battery is fully charged and run flashing procedure once again. If some error appears, save log file and post it here, without serial numbers. Best Regards GSMServer team |
12-08-2009, 10:32 | #4 (permalink) | |
Member: 32738 Status: Offline Thanks Meter: 32 | Quote:
Loading RAM downloader for bootloader... Erasing flash memory... Erase completed! Flashing code group 0... Code group 0 flashed Flashing code group 1... Code group 1 flashed Flashing code group 2... Code group 2 flashed Flashing code group 3... Code group 3 flashed Flashing code group 4... Code group 4 flashed Flashing code group 7... Code group 7 flashed Flashing code group 15... Code group 15 flashed Flashing code group 17... Code group 17 flashed Flashing code group 18... Code group 18 flashed Verifying checksums... Code group 0 checksums match Error verifying code group 1 - checksums mismatch Error verifying code group 2 - checksums mismatch Error verifying code group 3 - checksums mismatch Error verifying code group 4 - checksums mismatch Error verifying code group 15 - checksums mismatch Error verifying code group 17 - checksums mismatch Code group 18 checksums match Flash failed | |
12-08-2009, 10:51 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ ozeracar, Try to flash the phone with the V3xx_R26111LD_U_96.66.73BR_lp002D_USIZRGBLBALRTR26 11101E_full_flash.mfw via Prepare Smart TestPont procedure . Best Regards GSMServer team |
12-08-2009, 14:25 | #6 (permalink) | |
please watch this video mr. because you dont understand me. http://ozeracar.azbuz.com/viewVideo....00000001192078 | |
12-08-2009, 14:36 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ ozeracar, Error always appears at the same time? If yes, more likely that the handset has some hardware malfunction one of possible reasons for it could be damaged Flash IC. Best Regards GSMServer team Last edited by GSM_Support; 12-08-2009 at 16:51. |
v3xx untypical can't power after unlock | segun4u | Smart-Clip | 17 | 09-18-2009 08:18 |
V3xx USB not working after Unlock | Jens23 | MSS Box II | 3 | 10-18-2008 16:22 |
V3xx at&t no network after unlock | ericnite101 | Smart-Clip | 4 | 08-14-2008 12:44 |
v3xx onely flash mode after unlock failed! | .:bono:. | Smart-Clip | 22 | 07-22-2008 08:25 |
fisio 355 cant booth after unlock | obioha | Redbox | 8 | 04-01-2006 19:25 |
