Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 12-06-2008, 12:25   #1 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 55
V9 polish PLAY network; phone unlocked by smartmoto 3.19 but still need unlock code !
hi
i have motorola V9 from polish PLAY network
phone had version R263313_U_A0.02.03R3 i flash it via scoute fullflash file: V9_PL_R263313_U_A0.03.18R_PDS005_LP002F_DRM2001_VS TU_302_0c_JPJAVA_U_A0_R263313_06_00_02R_USEMERALD2 100RTPLR263313008_1FF_Retail_Polish
to unbrand it. phone working OK with PLAY simcard. now i'm trying to unlock it several times:
SmartMoto 3.19
S-Card: xxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxx Europe, initializing... OK
Clip serial: xxxxx, version: 4.08, initializing... OK
Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... OK
Model MOTORAZRV9
Firmware R263313_U_A0.03.18R
Switching to flash mode... OK [S Flash Argon]
Reading phone boot version... 5.80
Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1803110644B65851.bk_
Processing data, 6 of 6 block...OK
Sending boot... OK
Erasing flash memory OK
Sending firmware OK
Searching for phone... found S Flash Argon
Reading phone boot version... 0.00
Reading flash id... AMD - S29WS512P
Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9
Hardware IMEI: 000000000000000
IMEI OTP status: unlocked
Security area saved to "PDS for S Flash Argon 000000000000000 (7).mbk"
Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1803110644B65851.bk_
Restore OK
Unlocking phone... OK
Turning phone off... OK
but V9 still want unlock code. i try 00000000 but not working.
how to unlock it? i had that phones before and after third time of unlock phone became unlocked but that unit is really solid
please how to unlock it? maybe i should use older 3.16 version?
i relash phone to original version V9_R263313_U_A0.02.03R3_PDS005_LP0037_DRM2001_VSTU _302_0c_JPJAVA_U_A0_R263313_06_00_02R_USEMERALD210 0P4PLR26331302C_1FF_Play_Poland_locked.pcf
and i tried again to unlock three times for ver 3.19 and older which was working for that v9 phones but after UNLOCKED OK info phone still wants unlock code.
HOW to unlock it ?
Old 12-07-2008, 04:00   #2 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
Phone was not Supported for Unlock, New Coding
Old 12-08-2008, 08:17   #3 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ PSG,
If SmartMoto read phone's IMEI number like this:
It shows that the handset is locked with the new type of encoding, that is not currently supported.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 12-08-2008, 10:59   #4 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 55
just great! i any view for update?
Old 12-08-2008, 11:05   #5 (permalink)
Member: 229997
Thanks Meter: 636
@ PSG,
As soon as the solution will be ready, the update will be released.
Phone models that are locked with the 16 digits subsidy pass are not currently supported for the unlock procedure.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 12-08-2008, 11:29   #6 (permalink)
halongmobile's Avatar
Member: 45580
Thanks Meter: 48
Flash new fw then.....unlock again ok.
Old 12-08-2008, 13:26   #7 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 55
@Mr.Tinkertrain
i'm not sure how many digits are needed to unlock because after i put 8th digit "OK" field becoming ready to press so maybe it's 8digit?
@halongmobile
phone originally has firmware R263313_U_A0.02.03R3. i try to unlock with that version and higher version R263313_U_A0.03.18R also.
what firmware do you suggest to flash? could you drect me ?
Old 12-08-2008, 13:48   #8 (permalink)
Member: 229997
Thanks Meter: 636
@ PSG,
How many digits can be placed in the subsidy pass field?
@ halongmobile,
Flashing with higher firmware version won't solve the problem.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 12-08-2008, 15:20   #9 (permalink)
PSG
PSG's Avatar
Member: 27761
Thanks Meter: 55
8 but there are more free place and maximum could be 16
Old 12-08-2008, 15:26   #10 (permalink)
Member: 229997
Thanks Meter: 636
@ PSG,
The phone you have definitely locked with the 16 digits subsidy pass, that is not currently supported for the unlock procedure.
Please wait for future updates.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Coral 640 unlocked but still asking NP codes.. . lester_oh Infinity-Box 32 07-26-2010 09:52
t303 unlock ok by smartmoto 3.21 daryl007 Smart-Clip 0 03-31-2009 23:17
XDA 2 unlocked but still requests unlock code? heramiah NSPRO 1 03-20-2009 02:37
w450 unlock ok but still ask for code ricson Smart-Clip 6 11-29-2008 16:31
C975...Have unlocked but still wants subsidy code miter Motorola P2k 1 04-19-2006 11:20
Page generated in 0.17931 seconds with 9 queries
