12-10-2009, 10:54 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Age: 40
Member: 213681 Status: Offline Thanks Meter: 108 | V9 problem after Unlock via TP Now my v9 is hanging When i power on the phone i have motorola logo, next the "HELLOMOTO" and the phone it is hanging on hellomoto !! When i push the button i have sound, after one minute i have screen saver and i can power off the phone with power off button! When i whoas unlocking i have some like this Info: "You have save to c:ble/ble/ble/fbp_V9_Argon_05F4.sfb please send this file to [email protected]" It is important?? Can you help me with this problem smart clip team br balar |
12-10-2009, 11:22 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | @ balar, How many digits subsidy pass the handsets asked for? Was it 16digits subsidy pass or 8 digits? Best Regards GSMServer team |
12-10-2009, 11:48 | #5 (permalink) | |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | @ balar, Quote:
Now, try to flash the phone with the same firmware version like it originally had or higher one. After flashing procedure completes, post results here. Best Regards GSMServer team | |
12-10-2009, 12:16 | #7 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | @ balar, Read phone info with the SCout flasher and after that Flash the set with the same firmware version like it has or higher. For flashing purposes use SCout flasher and *.pcf flash files. Flash files available at the Boot-Loader.com Best Regards GSMServer team |
12-10-2009, 15:50 | #8 (permalink) |
Member: 213681 Status: Offline Thanks Meter: 108 | I flashed this v9 with : R263313_U_A0.02.0AR_PDS005_LP0021_DRM2001_VSTU_302 _0c_JPJAVA_U_A0_R263313DI_05_00_08R_USEMERALD2100I DRETS3R263313042_1FF_Retail_Indonesian.pcf and R263313_U_A0.02.03R3_PDS005_LP0037_DRM2001_VSTU_30 2_0c_JPJAVA_U_A0_R263313_06_00_02R_USEMERALD2100P4 PLR26331302C_1FF_Play_Poland_locked.pcf And still the same problem |
12-10-2009, 16:14 | #10 (permalink) | |
Member: 213681 Status: Offline Thanks Meter: 108 | A don't know because is flashed phone after simlock Quote:
I thing there is problem with simlock area because when i putt universal sim card the phone is power on normal. When i put sim card from some brand i have this problem. Last edited by balar; 12-10-2009 at 16:22. | |
12-10-2009, 16:17 | #11 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,773 | @ balar, Try to insert original SIM card in the handset and check whether it will hang or no. Best Regards GSMServer team |
12-11-2009, 09:57 | #12 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Philippines
Member: 218941 Status: Offline Thanks Meter: 1,801 | Quote:
YOU ARE RIGHT SOMETIMES phone cant go to menu coz of sim protection... | |
12-15-2009, 15:41 | #13 (permalink) |
Member: 213681 Status: Offline Thanks Meter: 108 | Hi all! I still have problem with this v9 ! I flashed this phone and unlocked again but still the same problem Log from unlocking: Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... OK Model MOTORAZRV9 Firmware R263313_U_A0.03.43R_O Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 5.F4 Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1A03120D44B65851.bk_ Processing data, 6 of 6 block...OK Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... OK Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 5.F4 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S29WS512P Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 000000000000000 IMEI OTP status: unlocked Security area saved to "PDS for S Flash Argon 000000000000000 (2).mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1A03120D44B65851.bk_ Restore OK Unlocking phone... OK Can you help me?? |
12-15-2009, 16:00 | #14 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: location,location....
Member: 411486 Status: Offline Thanks Meter: 68 | Quote:
12-15-2009, 16:20 | #15 (permalink) | |
Member: 213681 Status: Offline Thanks Meter: 108 | Quote:
problem with unlock via TP flash memory spansion | uki | Universalbox | 0 | 09-29-2008 12:45 |
6280 dead after make unlock via tp | melgsm | Nokia Hardware & Hardware Repair | 5 | 03-29-2008 14:23 |
My 101x self charging after unlock via TP. | rajumobile | Sagem Hardware Repair Area | 2 | 04-08-2006 16:54 |
My 101x self charging after unlock via TP. | rajumobile | ARM9 BASED M62 / M62+ | 0 | 04-07-2006 07:46 |
Samsung V200 problems after unlock via codes | G0dX | Trident/AGERE Platform | 2 | 07-18-2003 11:10 |
