08-07-2006, 00:55 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: none Age: 49
Member: 11926 Status: Offline Thanks Meter: 0 | v975 call failed after unlock I unlocked a v975 with smart clip, removing rsa method, but now it fails getting network, and when network is full, it fails making the call can anybody help me please ? |
08-07-2006, 08:31 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ noone0, Please, try to perform Repair PDS option and after that Full Flash the phone with the same or higher firmware version. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-07-2006, 08:41 | #3 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | hi there 1st cheak its settings 2 go at settingz n then cheak its band slection n cheak its caller id then post here whts up i think its just settings pro wbr m. ahmed |
08-08-2006, 19:02 | #5 (permalink) |
Member: 11926 Status: Offline Thanks Meter: 0 | I repaired PDS and flashed with R24_U_80[1].3F.A5I_lp0039_full_flash.smf (this was the same version of the phone)... it has network, but its up and down, and I can't make calls Afeter that I flashed with R245_U_82[1].31.56I_lp0039_full_flash.smf (without repair PDS and stills the same. Need some help to repair this, because the phone was OK before the unlock. |
08-09-2006, 09:12 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ noone0, Please try to flash the phone with higher firmware version. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-11-2006, 15:34 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ noone0, What firmware version you have used to flash the handset? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-12-2006, 10:27 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ noone0, As I see from your posts, you have not disassembled the phone. But if you can, please, make sure that antenna connected properly. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-12-2006, 14:42 | #11 (permalink) |
Member: 11926 Status: Offline Thanks Meter: 0 | checked and antenna is fixed correctly..... this can only be a software problem.... Is there any way to flash the boot area (the one 5.f.1) to other version ? I believe this could be the problem |
08-14-2006, 15:55 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ noone0, the only boot file that we have is V975_boot_5.F.1.smf you can try to flash the phone with it and after that perform Full Flash procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
z240 call failed after unlock | rajufzr | NSPRO | 4 | 10-05-2009 11:59 |
Db2020 Call Fail After Unlock | mishaelwillo | Infinity-Box | 7 | 05-31-2007 17:39 |
my501x call fail after unlock | gorgans | SAGEM JTAG UNLOCKER | 5 | 01-10-2007 16:15 |
help v975 calle failed | samirsana | Motorola P2k | 0 | 08-19-2005 10:43 |
c550 call failed after unlock | DarkSkir | Motorola P2k | 2 | 04-01-2005 16:56 |
