Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2004
Member: 93717 Status: Offline Thanks: 0
| V975 STUCK AT ERROR:0x1DE I was unlocking v975, I got to stage where I press *,# and power, as usual phone displayed error:0x1DE but when I pressed ok on computer screen, smart moto displayed phone not found, I have tried 20 times but still phone not found. It is not the smart-clip or cable as I successfully unlocked a v975 afterwards. Any idea how to get smart-moto to recognise phone so I can continue with unlock procedure or flash phone. thanks |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001 Location: ENGLAND
Member: 3811 Status: Offline Thanks: 3
| hi make sure you have 0x1DE on the screen with mobile connected to smart moto then go into remove RSA in smart moto then from the drop down list pick v975 press remove RSA this will complete the procedure make sure you have full battery regards |
| | #5 (permalink) |
| make sure you have full battery and hold the cable connector to mobile i had the same problem do you get found s blank rainbow pog getting test interface when smart clip is found by smart moto..... |
| | #8 (permalink) |
| I don't get found s blank rainbow pog getting test interface just no phone found where is read phone in smart moto? there is read language pack but if I selecy this smart moto says connect phone first |
| | #9 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2003 Location: Town City Age: 43
Member: 37735 Status: Offline Thanks: 159
| Use REPAIR Cable. Sometime you can try to force boot mode by Keypad.Use your left hand to hold tight the cable to the phone and click Serch then Remove RSA. |
| | #11 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Thanks: 445
| Check the cable & connector... Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
| | #12 (permalink) |
| [QUOTE=SC_SUPPORT]Check the cable & connector... cable and smart-clip is good, I have unlocked 2 v975 afterwards without any problems. I have tried other cables also but no luck, also I think connector is ok because smart-moto detected phone originally and was working until the error part of the downgrade process. |
| | #14 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks: 217
| use exactly 4v to your mobile using DC supply. then turn on your phone into boot mode by *+#+ power button then do unlock RSA again. this time press down your cable tightly to the phone when u connect to smart-clip |
| | #15 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002 Location: Africa
Member: 8843 Status: Offline Thanks: 255
| have tried to remove error:0x1DE on V975 but to no avail. pliz give again step by step. also cable schematic is showing shorted pins 3+6 and 13+14 but the one schematic for forced boot in pdf file has no shorted pins 13+14. thanx in advance |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help : V975 stuck with Error 0X1DE | rbalu72 | P2k Series | 5 | 08-23-2008 16:30 |
| v975 stuck on the flash mode during the flash | tunjay | P2k Series | 0 | 07-20-2005 23:39 |
| V975 Stuck in Test Mode - Code Corrupt | Mobilesunlocked | Smart-Clip | 6 | 07-04-2005 12:52 |
| V975 Stuck in Test Mode - Code Corrupt | Mobilesunlocked | Smart-Clip | 0 | 06-29-2005 16:12 |
| t68i band stuck at 900, cant use 1900? | btyazoo | Sony Ericsson | 4 | 04-05-2004 17:40 |
