05-14-2006, 00:15 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: <<<...sPaCe...>>>
Member: 171153 Status: Offline Thanks Meter: 30 | v980m FAILED INITIAL SECURITY VERICATION CHECKS Secure Blank Rainbow POG the boot loader is v0x000310 you cannot search for the phone under information says: Searching for phone... found Motorola P2K, getting test interface... interface not found Searching for phone... found Motorola P2K, getting test interface... interface not found Phone security power up error. ERROR: Phone failed initial security verification checks. HAB error 0x27. Searching for phone... Cancelled Searching for phone... Unable to connect to the Subscriber Unit. Unable to retrieve interface handle when you insert the phones battery and connect to sm It Does Not Boot To Main screen only flash mode but it cannt be flashed it says phone security power up failure PHONE FAILED INITIAL SECURITY VERICATION CHECKS. HAB error 0x27 any suggestions to solve this problem |
05-14-2006, 12:14 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 44
Member: 173810 Status: Offline Thanks Meter: 2 | connect all the things all over again and start the procedure new make sure you will use remove RSA method not Test Point method select V975 intead of v980 right.goodluck |
05-15-2006, 08:55 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello Dimortal, Please post a log file, it would spread some light on your problem. P.S. Do not forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Initialization has failed -> Security Card is expired. Refill it. | ramcellular | Cyclonebox | 3 | 12-07-2010 07:32 |
Initialization has failed -> Security card was not found! | bighiner | Cyclonebox | 0 | 01-08-2010 10:55 |
phone failed initial security checks.HAB error 0x3B | meisam | Smart-Clip | 1 | 09-09-2008 11:49 |
[Motorola V3x] Phone failed initial security verification checks. HAB error 0x8D | loki07 | Motorola P2k | 2 | 04-18-2008 03:37 |
Phone failed initial security checks.HAB error 0x8D | pmapurangah | Motorola P2k | 3 | 01-03-2007 21:02 |
