11-28-2008, 09:53 | #1 (permalink) |
Registered User Join Date: Sep 2006
Member: 347110 Status: Offline Thanks Meter: 34 | V9unluck done but still locked Last edited by GSM_Support; 11-28-2008 at 09:56. Reason: Contained serial number |
The Following User Says Thank You to firmanbali For This Useful Post: |
11-28-2008, 10:03 | #2 (permalink) |
Member: 347110 Status: Offline Thanks Meter: 34 | sorry with contained serial number, here is log: SmartMoto 3.18 S-Card: xxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxx version: 4.08, initializing... OK Searching for phone... no phone found Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... OK Model MOTORAZRV9 Firmware R263313-AS_U_A0.03.24R2 Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 5.80 Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_09030E1554BA4453.bk_ Processing data, 6 of 6 block...OK Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... AT command error Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... AT command error Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... AT command error Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... AT command error Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... OK Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 5.80 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S29WS512P Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 000000000000000 IMEI OTP status: unlocked Security area saved to "PDS for S Flash Argon 000000000000000.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_09030E1554BA4453.bk_ Restore OK Unlocking phone... OK Turning phone off... OK |
11-28-2008, 10:06 | #3 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ firmanbali, IMEI number from your log file shows that the handset you have is locked with the new type of encoding. Quote:
Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
11-28-2008, 10:18 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ firmanbali, Unfortunately, V9 that are locked with the new type of encoding are not currently supported for the unlock procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-01-2008, 16:21 | #7 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | Some problem Model MOTORAZRV9 Firmware R263313_U_A0.03.1DR Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... OK Model MOTORAZRV9 Firmware R263313_U_A0.03.1DR Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 5.80 Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1F03101344B65851.bk_ Processing data, 6 of 6 block...OK Searching for phone... found Motorola Phone (MOTORAZRV9), getting test interface... OK Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 5.80 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S29WS512P Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 000000000000000 IMEI OTP status: unlocked Security area saved to "PDS for S Flash Argon 000000000000000 (1).mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_1F03101344B65851.bk_ Restore OK Unlocking phone... OK Phone stil locked! |
12-01-2008, 16:24 | #8 (permalink) | |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Pufi164, As can be seen from your log file IMEI number get read as 000000000000000 Quote:
e900 unlock done but still locked | gsmservices | NSPRO | 5 | 03-16-2009 17:20 |
my150 unlock done but still locked | Umair Rashid | FuriousGold | 4 | 09-01-2008 17:06 |
zte A36 unlock done but still locked | tolski | Infinity-Box | 8 | 05-29-2008 14:57 |
e100 unlock done but still lock | ricson | Multi-box LITE | 17 | 01-22-2008 13:11 |
th4 can't with polar and with vygis cracked, unlock done but still locked!! | .:bono:. | BF, BG, TH, BHx Series | 5 | 11-07-2005 07:49 |
