Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 566229 Status: Offline Thanks: 15
| I mates I have a motorola w175g locked to Tracfone, I tried unlock with smart clip which did not wrk, I then tried repair and fone now says Hacked....I need w175g Flash file.. |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2006
Member: 229997 Status: Offline Thanks: 252
| @ silverlink, All available flash files are placed at the boot-loader.com. ![]() Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007 Location: USULUTAN, EL SALVADOR. Age: 36
Member: 545374 Status: Offline Thanks: 91
| as far as i know, there is not solution for the w175g from tracfone, i just tried to flash 1 with a w175 flash file and now the w175g is dead. br juvenile |
| | #5 (permalink) |
| I chked boot-loader and only found 1 files under w175g and it did not recover the fone.........I need the files for a w175g Tracfone please boot-loder, I bought smart clip and scout dongle ...because they where claimed to be the best ........ Again please I need motorola w175g Tracfone |
| | #6 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: Central Europe Age: 28
Member: 239548 Status: Online Thanks: 343
| Have you flashed the phone with firmware 6.2.57.K3.LP_W175_6257_NA03.FLEX_W175_A0_006_101.s fl ? What is result of flashing? |
| | #11 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005
Member: 152752 Status: Offline Thanks: 98
| Select W175 and then follow smart clip unlock procedure. Use Smart-Clips SCard. W156, W160, W175, W177, W180, W230, W270, W360, W388 For unlock purposes the models W156, W160, W175, W177, W180, W230, W270, W360, W388 require to be connected to PC USB port. 1. Connect S-Card and Mini USB data cable to PC USB port and launch SmartMoto. 2. Select "Computer COM ports" in Phone connection area. 3. Log to the tab "Compal models" 4. Choose an appropriate model from the list. 5. Press Unlock button. 6. SmartMoto will inform "Connect phone to computer USB port before proceeding". 7. Connect data cable to the powered OFF phone with inserted battery. 8. The SmartMoto will automatically (no user intervention is required during the installation) install "Locosto flash interface" driver and display the following message: "reconnect phone and try again". 9. Disconnect data cable from the phone, remove and insert the battery back to the phone. 10. Connect data cable and press Unlock again. 11. The unlock process continues. 12. Message "Unlock ok" informs that process is finished and the phone can be disconnected. NOTE For unlock purposes the only driver that is required is the "Locosto flash interface" driver. No need to install the phone W156, W160, W175, W180, W230, W270, W360, W388 model driver. |
| | #14 (permalink) | |
| Quote:
This phone has 850/1900MHz band frequency. We have 900/1800MHz band. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| ..:: [ All Sharp Flash Files ] ::.. | ..::Neo::.. | Sharp | 375 | 05-18-2013 23:04 |
| ..:: Nokia Flash File ::... | Ranamubashir | Nokia Hardware & Hardware-Repair Area | 1 | 10-12-2009 12:45 |
| ..:: Suspicious flash file detected. Report the of*****ng flash file here ::.. | Mainboard | Cruiser Suite | 67 | 10-10-2008 16:23 |
| ..:: How to flash CID49 phones with CID51 flash files ::.. | Mainboard | Cruiser Suite | 1 | 01-29-2007 21:57 |
| ..:: Sagem Flash Files ::.. | ..:: i-MAX ::.. | SwS_SaG_BoX | 7 | 06-14-2006 14:42 |
