02-21-2008, 13:16 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Why do you want to flash HW6 to W220 HW7? Press *#**372#, go to "Sw ver&model", then check hardware version before downloading the main code. For example, TCT-000, S1, 390,D7.H8,Lb... means that you should use this file SCY-7-1120-R360-001_LP020.sfl for flashing. Note: if the hardware and the software does not match, it will cause download failure. |
03-24-2008, 00:48 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | You have to change the two filters (850Mhz) of its w220, two filters, frequency (900/1800) compatible with the v172, c168 and w220. After have a full flash (fss, image, melody etc.), the operator Claro (Brazil) by the infinity-box and unlock via smart-clip. |
03-24-2008, 01:48 | #5 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Davao City
Member: 305365 Status: Offline Thanks Meter: 90 | according to your picture sir, no resistor transfer to change band only making jumper of filter. Is it 900mhz is working very will? Do I need to flash the firmware? I have here cingular but I couldn't convert it. By the way I didn't flash the phone, I only unlocked it then do the hardware based on your picture. |
06-18-2008, 01:21 | #6 (permalink) |
Member: 689942 Status: Offline Thanks Meter: 312 | Replace these filters w220 the other are from a unit that works in the frequency of 900/1800 Mhz , these filters can be found in slabs of v172 and other models and also in LG models (eg c1100), then you make a flash of an operator who work in 900/1800. The image of this link without the filters, but you need to put in place that the two missing in this picture If necessary tomorrow I put the names of the files that I use to make a flash in the infinity-box. |
TomTom Maps convert | gordo52 | GPS devices , Navigators & Maps | 0 | 03-29-2010 11:57 |
How change 1.b4 convert 1.b1 | yahoo.mobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 11:27 |
help w220 convert 850/1900mhz to 900/1800mhz | khuletsky18 | Motorola Hardware Repair | 5 | 04-26-2009 13:25 |
moto w220 convert to 900 | yurais | Infinity-Box | 1 | 08-24-2008 17:30 |
Need convert W220 900/1800 to 850/1900 | toto221 | Motorola ODM | 0 | 11-24-2007 16:21 |
