01-14-2008, 21:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: United Kingdom, ENGLAND
Member: 47774 Status: Offline Thanks Meter: 185 | w490 after unlock PH SIG ERR:39:02: i have try to unlock W490 with smart clip Via Smart TP but after do Prepare i have put the battery back is on boot mode and show this Error PH SIG ERR:39:02: any idea how can i slove this problem Thanks PS : i have try to Flash and repair PDS but allways fail or timeout Best Regards, Morfeus |
01-15-2008, 08:44 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ .:Morpheus:., Please provide us with more detailed information. Was unlock procedure completed successfully? What firmware version the handset originally had and what flash files have you used to flash it? Please show us some log files, don't forget to hide serial numbers. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-15-2008, 08:49 | #3 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Watchin Over You...
Member: 535621 Status: Offline Thanks Meter: 4 | Quote:
the instructions doesnt say that u have to put back battery & turn on after prepare. it says disconnect & disassemble phone & connect tp. ur not following instructions. now, whos fault is it?... | |
01-15-2008, 12:18 | #4 (permalink) |
Member: 47774 Status: Offline Thanks Meter: 185 | man when i have Connect the power the phone is on boot mode now i want to Flash the phone any idea how pleasee is sayin allways sending boot timeout even i have try with TP SmartMoto 3.02 S-Card: ****** Smart-Clip dongle, v 2.01, assigned Smart-Clip: ******X Europe, initializing... OK Clip serial: ******X, version: 4.01, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 io timeout Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 io timeout Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 io timeout Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 io timeout Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 io timeout Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 io timeout |
01-18-2008, 08:28 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | Man, i have the same U and i sloved by SCout + W510 full flash file. Try it and all will be OK, Good luck! Log when Smart TP error: SmartMoto 3.03 S-Card: 26******x Smart-Clip dongle, v 2.01, assigned Smart-Clip: 36******x Europe, initializing... OK Connect phone to Smart-Clip before proceeding Clip serial: 36******x, version: 4.01, initializing... OK Searching for phone... found Motorola Phone (W490), getting test interface... OK Model W490 Firmware R452G_G_08.24.02R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.50 Sending boot... OK Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F929A73314953FFA.bk_ Searching for phone... found Motorola Phone (W490), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.50 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... clip communication failed Searching for phone... clip communication failed Searching for phone... clip communication failed Searching for phone... clip communication failed Searching for phone... clip communication failed Searching for phone... clip communication failed |
01-18-2008, 15:15 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ nycu, Check band settings, please. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-18-2008, 16:07 | #9 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Castellon de la plana, Spain Age: 41
Member: 194609 Status: Offline Thanks Meter: 46 | @ Mr. Tinkertrain Can you please tell me where can I buy a working Smart testpoint cable in Romania because mine it seem's is not good? Tell me what reseller do you have here. |
01-21-2008, 09:28 | #11 (permalink) | |
Member: 194609 Status: Offline Thanks Meter: 46 | Quote:
If SCout doesn't work use Flas & Backup from www.moodmymoto.com | |
04-01-2008, 03:59 | #13 (permalink) |
Freak Poster Join Date: Aug 2005
Member: 170728 Status: Offline Thanks Meter: 3 | Me too, I ask the same question to Morpheus, cause I have the same error. Now more and more Smart clip users have this error on w490/w510 phone, I think its about time Smart clip team pay close attention to this phone. |
04-01-2008, 09:26 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ bhart & alswedi, Please provide us with more detailed information about your problem. Show us some log files. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-15-2008, 21:44 | #15 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: albania
Member: 133415 Status: Offline Thanks Meter: 46 | Quote:
w490 after unlocked display no light | chandy pok | Motorola Hardware Repair | 22 | 10-30-2009 11:21 |
w490 boot mode PH SIG ERR:39:02 | rmenganag | Smart-Clip | 8 | 10-16-2009 15:59 |
w490 after unlock PH SIG ERR:39:02: Problem solve | jakoy | Smart-Clip | 2 | 01-17-2009 06:27 |
V3RE after unlocking <PH SIG ERR>SHOW.. ON MOBILE SCREEN | multicom_fsdpk | Smart-Clip | 5 | 06-07-2008 09:01 |
Problem prepaire w510 !!! PH SIG ERR:39:02: | Juanitoesn | Smart-Clip | 12 | 11-29-2007 19:45 |
