04-15-2008, 21:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: albania
Member: 133415 Status: Offline Thanks Meter: 46 | W490 Sig Err:39:02: io timeout I START WITH FIRST STEP BUT NOW Switching to flash mode... OK Reading phone boot version... C.50 io timeout AND THE PHONE NOW IN DISPLAY HAVE ERR:39:02: I SEE OTHER THREAD SO DONT TELL ME SEE POWER BEXOUSE I HAVE GOOD POWER (ORG) OLSO I HAVE UNLOCK WITH SMART TP MANY MANY MOTOROLA LIKE THIS.THIS IS THE SOFTWARE PROBLEM I NEED TO SLOVED IT . IS ANY SOLUTION SMART-CLIP TEAM? |
04-16-2008, 07:30 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ bebiloku, io timeout error shows that the handset didn't respond for too long time. Such error usually appears in case if the power supply is low or the battery wasn't charged. Try to fully charge the battery and run unlock procedure once again. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-16-2008, 08:06 | #3 (permalink) | |
Member: 133415 Status: Offline Thanks Meter: 46 | Quote:
04-16-2008, 10:18 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ bebiloku Please tell us what firmware version your phone has. Also, please check the mainboard of the phone, ensure that it doesn't have any malfunction, short circuit and the TP Area is clean. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-16-2008, 10:51 | #5 (permalink) | |
04-16-2008, 11:06 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Jr Telecom™
Member: 409725 Status: Offline Sonork: 100.1581478 Thanks Meter: 797 | I unlocked that phone no any accident ........ Quite and composed ........... U can start to unlock again and procedure completed then (while apear on screen)reflash ur phone.... |
04-16-2008, 15:11 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ bebiloku, try to use external power supply and run unlock procedure once again. As an option try to use another battery for the phone. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2008, 14:42 | #9 (permalink) |
Insane Poster Join Date: Mar 2005 Age: 53
Member: 126522 Status: Offline Thanks Meter: 10 | motorola w490 have the same problème .tring to unlock phone phone tel me, Reading phone boot version... C.50 io timeout ''' test 2 more times afther That nothing more happent only green light on front of phone is lithing any help please |
05-05-2008, 14:52 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ k-cell, During successfull Prepare Smart Testpoint procedure boot version suppose to be read as 0.00. What cable did you use to unlock the phone? What power supply you use with the Smart-Clip? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2008, 23:44 | #11 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | IO Timeout. You must repeat the entire procedure,and its not necessary to assemble phone and connect LCD. Just remove red power clip from smartTP, apply your power source and click search. Should find bootloader version... C.50 Now select model W490 and prepare phone once again. You will see warning message....ignore because you already have a backup. Note.......when the LCD is disconnected from the phone and power is applied, the phone will automatically power on. |
w490 after unlock PH SIG ERR:39:02: | .:Morpheus:. | Smart-Clip | 47 | 05-19-2011 07:30 |
w490 boot mode PH SIG ERR:39:02 | rmenganag | Smart-Clip | 8 | 10-16-2009 15:59 |
w490 after unlock PH SIG ERR:39:02: Problem solve | jakoy | Smart-Clip | 2 | 01-17-2009 06:27 |
Problem prepaire w510 !!! PH SIG ERR:39:02: | Juanitoesn | Smart-Clip | 12 | 11-29-2007 19:45 |
