02-06-2008, 18:40 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 60
Member: 131801 Status: Offline Thanks Meter: 5 | w490 unlock problem S-Card: ???????? Smart-Clip dongle, v 2.06, assigned Smart-Clip: ??????Europe, initializing... OK Clip serial: ???????? , version: 4.06, initializing... OK Searching for phone... found Motorola Phone (W490), getting test interface... OK Reading <Model>... clip communication failed Searching for phone... found Motorola Phone (W490), getting test interface... OK Model W490 Firmware R452G_G_08.24.02R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.50 Sending boot... 29% clip communication failed failed error C4 the battery is fully charged and i have used this cable many times what this dam error |
02-06-2008, 18:54 | #2 (permalink) |
Member: 131801 Status: Offline Thanks Meter: 5 | failed error C4 the battery is fully charged and i have used this cable many times what this dam error till this log i had not connect the test point cable do you think that this error came as the result of non using test point but until this step i have reached it is not necessary to use test point as a unlock manual mentioned Last edited by mohmohsah; 02-06-2008 at 19:00. |
02-06-2008, 19:07 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Check ur Smar Clip voltage it sould be 12v and 750mA and also use original Motorola cable and Smart TP Original from GSM Server but... Its problem from voltage i had same problem and now i am using 12v and 750mA and unlock any moto fone by Smart TP so ma that the reason.....make sure u are doing ok TP BR, Tito Millo |
02-06-2008, 19:28 | #5 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
02-06-2008, 21:19 | #7 (permalink) |
Member: 131801 Status: Offline Thanks Meter: 5 | you are right i have raised the v to 11.5 the prepairing complete but after test point i have got the following log what nis the proplem Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... no phone found Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... C.50 now the phone in boot mode |
02-06-2008, 21:36 | #8 (permalink) |
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Listen i had the same problem i conect TP read same boot as it was w/o TP and then get Clip Comunication Failed so i read sticky tried giving enough power supply and now i can unlock any fone si i had same problem as him BR, Tito Millo |
02-07-2008, 08:34 | #9 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ mohmohsah, Please provide us with more detailed information. What cable you are using? Where have you purchased it? You connect Primary TP only or both TPs simultaneously? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-07-2008, 12:31 | #10 (permalink) |
Member: 131801 Status: Offline Thanks Meter: 5 | my phone now in boot mode so 1-i have connected test point A as your unlock manual and 2-i made search again with information the s-moto read phone in bootmode 3-then i have disconnect test point A 4-then i have chosed prepare then unlock with via test point 5-i have used the primary test point A just . but my problem after test point and reading boot i have got phone not found do you rcommand me to use the secondry tp or both of them in the same time or what my phone now in boot mode but as i mentioned above i can reache to the prepare then unlock via test point |
02-07-2008, 13:15 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mohmohsah, Please read manual carefully.
02-07-2008, 13:50 | #12 (permalink) |
Member: 131801 Status: Offline Thanks Meter: 5 | i have read the manual carefully but you have to read my problem carefully too i have fowlled yor steps carefully till the programm ask me to connect test point i have connect test point but after ok the programm reading the boot phone not found with test point a return to the lase thread to konow that my phone now in boot mode please read it again why phone not found did you recomanded me to use test point b |
02-07-2008, 14:04 | #13 (permalink) | |
Member: 229997 Status: Offline Thanks Meter: 636 | As mentioned in the manual Smart TestPoint cable has to be connected after SmartMoto Pop Ups window to connect it. You have written that you connect the TestPoint and after that press search. Quote:
Where have you purchased it? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
02-07-2008, 14:22 | #14 (permalink) |
Member: 131801 Status: Offline Thanks Meter: 5 | i forced to use test point in reading information step because my phone was in boot mode my quesion is clear do recommand my to use test point b or not and how to back my phone to normal mode finally my test point cable is good why? because when i connect the cable to read phone info the phone get in flash mode ok and read the phone info |
02-07-2008, 14:54 | #15 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mohmohsah, The Smart TP has to be connected when SmartMoto Pop Ups the request for the TestPoint. Try to run unlock procedure exactly as written in the manual. In case if the phone won't be found run unlock procedure once again using both TestPoints (A and B) simultaneously. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
w490 unlock problem | doller | Smart-Clip | 1 | 12-18-2009 11:54 |
W490 Unlock problem | cargragon | Smart-Clip | 1 | 08-15-2009 07:26 |
w490 unlock problem | TUR@N ALAM | Smart-Clip | 4 | 07-29-2008 13:13 |
Problem with w490 unlock | manistar | Smart-Clip | 0 | 02-05-2008 13:55 |
unlock problem w490/510 | SmilingFace | Smart-Clip | 7 | 01-04-2008 12:15 |
