Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 07-10-2008, 01:57   #1 (permalink)
Member: 129043
w5 no display
hi frieds i unlock w5 by test point every think is ok but when turn it on the display gone inside but the other display is ok somebody tell me what i made wrong
Old 07-10-2008, 02:02   #2 (permalink)
Member: 810098
You did the Test Point connected with the display?
It may be the cause of the crash.
Old 07-10-2008, 02:35   #3 (permalink)
Member: 743931
first unlock via prepare method and full flash your phone
Old 07-10-2008, 02:51   #4 (permalink)
Member: 810098
Try to repair PDS and then applies a full flash in it.
Good luck.
Old 07-10-2008, 15:05   #5 (permalink)
TICTAC_M's Avatar
Member: 331361
you can serch solution like w490 or w5 in forum, the pcb is same and have same problems. and is probabily that you display is in on but back lights do not working, if is it problem is not for software, you can have pcb problem. serch solution with they model.
good luck.
Old 07-10-2008, 15:17   #6 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
@ karlitos210,
You can try to flash the handset with the same firmware version as it has, but more likely that the PCB of the phone is damaged.
In case if flashing won't solve the problem, please check the PCB of the phone.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 07-10-2008, 15:34   #7 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
That is 100% hardware fault mate.....
BR,
Tito Millo
V3 no display,no display light celluniversal P2k Series 21 11-21-2011 05:57
w5 no sim!!! pr1mux Motorola Hardware Repair Section 0 07-30-2008 19:38
V3 No Display N No Display Light? jimmyyew Motorola Hardware Repair Section 4 05-27-2008 08:33
ROKR W5 no display nost Motorola Hardware Repair Section 2 05-14-2008 04:31
After Unlock W5 No Light In Displays Why ?? jhoncorrea Smart-Clip 8 04-27-2008 18:18
Page generated in 0.62186 seconds with 11 queries
