10-31-2007, 09:50 | #1 (permalink) |
Insane Poster Join Date: Oct 2006 Location: inside GSM hosting
Member: 365116 Status: Offline Thanks Meter: 2 | W510i How to repair PDS ? On the screen always : Boot Loader 0C.50. SW Version: R452G_08.11.05R PH SIG ERR: 39:02: OK to Program Connect USB Data Cable Whn I try flash him with SmartMoto or RSD , wih files BootLoader 0C.50. , after boot we have : Critical Error 0085 00CA Prepare Smart TestPoint Operation log : SmartMoto 2.42 S-Card: XXXXXXX Smart-Clip dongle, v 1.50, assigned Smart-Clip: XXXXXXX Europe, initializing... OK Clip serial: XXXXXXX , version: 3.25, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... C.50 Sending boot... OK failed io timeout Then : Critical Error 0085 00CA As I think original boot 0C.50. in phone already patched by SmartMoto , but unsuccessfully or not up to the end. And now is impossible flashing phone by flash files with the loader 0C.50. How to repair this phone by means of SmartMoto ? P.S. TP Cable byed from SGMserver directly. |
10-31-2007, 10:04 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ er1cc, This firmware version can be found at boot-laoder.com in MFW and PCF file sections. Please make sure that you perform all steps correctly and try to run Prepare Smart TestPoint procedure once again (unlock automatically should be marked off), after that Full Flash the phone with the same firmware version like it has. If same error appears, please check the mainboard of the phone. One of possible reasons for such error is hardware malfunction, TP can not be connected properly. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
10-31-2007, 11:11 | #3 (permalink) |
Member: 365116 Status: Offline Thanks Meter: 2 | I asured that I perform all steps correctly 100% Log of prepare procedure look up. Files from Support section already downloaded. But phone can't be flashed , coz original boot 0C.50. in phone already patched by SmartMoto. HW of phone is OK 100% too. Any other idea's ? |
10-31-2007, 11:32 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ er1cc, Check the TP area, one of possible reasons for that error is damaged TP or not stable connection. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
10-31-2007, 13:07 | #6 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | @er1cc in my opinion bootloader version is not the problem sir. from your log as i can see is the box can not oacth the bootloader to version.... 0.00 so I suggest you to change your smart testpoint cable with another one. |
10-31-2007, 13:19 | #7 (permalink) |
Member: 365116 Status: Offline Thanks Meter: 2 | Cable byed from GSMServer Directly , and tested several time. And at what here TP Cable if procedure of prepare does not reach to that moment when it is necessary to connect Test Point Cable ? Any other ideas ? |
11-16-2007, 06:24 | #8 (permalink) |
Junior Member Join Date: Jan 2007
Member: 442004 Status: Offline Thanks Meter: 1 | Hello all, I have the exact same problem. The only difference is that my phone turns on perfectly and working but when I try to do the prepare smart test point operation, it reaches the point where it upload patch to S Flash Nepture LTE and as soon as 100% complete the phone screen shows Critical Error 0085, 00AC. I was passing this point earlier when I was trying to unlock it. I tried couple times and both times I had to use both TP A and B and it gave me error 9B while tryin to unlock. I just bought this Smart Test Point Cable from authorized reseller in Canada. It has one battery battery connection and two TP pins one is Yellow and other one is RED. The Part Number is " AT163 Smart TP ". Any idea what could be the problem? I have already checked the battery and charged it very well , also tried different battery (please dont say you dont need battery because for the half part you do need battery) . I also tried to provide power from my power supply but surprisengly it gives me Battery charge error with that (It probably detects the presence of battery). Any idea would be appreciated. Thanks |
11-16-2007, 11:53 | #9 (permalink) | |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Quote:
Also, what power supply did you use with your Clip? Best Regards GSMServer team Last edited by GSM_Support; 11-16-2007 at 12:00. | |
11-16-2007, 11:58 | #10 (permalink) | |
Please provide me with the handset firmware version and post a log file without serials. Best Regards GSMServer team | |
11-17-2007, 07:16 | #11 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: NCK, Logs, Server
Member: 23684 Status: Offline Sonork: 1582723 Thanks Meter: 684 | Quote:
I eats SmartClip (here 3th years) from a powerful power unit - 7v 3A. How to recover phone ? WBR ! | |
11-17-2007, 09:45 | #12 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | 7v 3A????? Where have you seen that Smart-Clip requires this kind of power supply? In very manual we state that Smart-Clip requires 12V, 750mA. Please use a correct supply and try again. Best Regards GSMServer team |
11-18-2007, 00:15 | #13 (permalink) | |
Let's solve common problemm with W510 ! I did not ask You where is Smart Clip Manual. And to submit 12 volt to 5-volt stabilizer , absolutely not necessarily. There is quite enough and 7 volt from a powerful source of a current. 12 volt it is necessary to submit in that case when You use the Chinese weak source of a current in which under loading the pressure falls up to the same of 7 volt. So in occasion of restoration patched Bootloader W510 ? | |
11-19-2007, 08:56 | #14 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Well... If you say so and if you are sure that 7V is enough... Then i am leaving it yourself... Good luck... Thread closed. Best Regards GSMServer team |
how to repair pds | live14 | Rocker Dongle (By Legija) | 3 | 07-06-2009 19:34 |
How to repair pds in V6? | celutek | Smart-Clip | 3 | 01-12-2009 08:23 |
How to repair PDS V3re by Smart Clip | Tamansu | Smart-Clip | 5 | 12-09-2008 16:28 |
How To Repair PDS Standalone with Smart-Adapter | Kanwalgee | Smart-Clip | 2 | 01-26-2008 13:36 |
v3rohs R3443U2 boot 0A.52 - how to repair PDS? | sorinm | Motorola P2k | 3 | 11-30-2006 04:55 |
