03-11-2009, 09:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | whats the procedure to unlok e1?? plz guide me the procedure to unlok motorola e1... asnd if it is tp based unloking then share tp here,.,, coz it is not in the support.. thanx in advance. |
03-11-2009, 09:13 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please specify the boot and fw version of the phone, first. P.S. TestPoint for this model is located at www.boot-loader.com, Public Downloads section >> TestPoints >> E398_E1.jpg Best Regards GSMServer team |
03-11-2009, 09:25 | #4 (permalink) |
Registered User Join Date: Aug 2007 Location: bohol philippines Age: 42
Member: 572549 Status: Offline Thanks Meter: 175 | boot loader 0A.02 unlock via prepare phone cycle no need tp............. |
The Following User Says Thank You to T0T0 For This Useful Post: |
03-11-2009, 09:28 | #5 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Here is the procedure that needs to be performed. Very easy, no TP needed. Best Regards GSMServer team |
03-11-2009, 11:59 | #6 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | I DID XACTLY AS SAID.. BUT ERROR.. HERE IS THE LOG.. SmartMoto 3.20 Looking for S-Card... not found (card readers searched: 0 of 1) S-Card: XXXXX Smart-Clip dongle, v 2.10, assigned Smart-Clip: XXXXXX Europe, initializing... OK Clip serial: XXXXXXXX, version: 4.08, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.02 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE Switching to flash mode... OK Reading phone boot version... A.02 clip communication failed Sending boot... clip communication failed failed clip communication failed Sending boot... clip communication failed failed clip communication failed Clip serial: XXXXXXXX, version: 4.08, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.02 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE Switching to flash mode... OK Reading phone boot version... A.02 load error Sending boot... io timeout failed error C4 WEN IT REACHES AT 98% ON SENDING BOOT THE FONE SHOWS AN ERROR MESSAGE THAT 'RDL SIG ERROR:39:02: AND THEN SMART MOTO SAYS LOAD FAILED , WHAT SHUD I DO NOW?? NOW FONE SAYS 'MEM_MAP BLANK SERVICE REQ'D' Last edited by peter002; 03-11-2009 at 12:07. |
03-11-2009, 13:28 | #8 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | What power supply do you use with your Clip? Was the phone's battery fully charged? Best Regards GSMServer team |
03-11-2009, 16:48 | #11 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | You haven't done the Prepare procedure correctly. Check out the manual and repeat the process again. Ensure you do all as it's described in the manual! If there was any mistakes made during unlock process, and the handset is in "MEM_MAP Blank" mode, then "Prepare" process has to be repeated and the handset has to be flashed with reflash or full_flash file. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
03-13-2009, 09:27 | #12 (permalink) | ||
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
03-13-2009, 12:44 | #13 (permalink) | |
Member: 599037 Status: Offline Thanks Meter: 103 | Quote:
and i m using 12v dc 1 amp adaptor..still gets that error. | |
03-13-2009, 14:40 | #14 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Reupdate your Clip and dongle after that. If you get any error during update - save a log and mail it to support[at]smart-clip.com Best Regards GSMServer team |
03-13-2009, 16:12 | #15 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | i hav tried that updating, but the updater says that no need to update ur klip, same with the scard.. but wen i tried to flash then at the sending boot to fone at 98% the fone shows 'RDL SIG ERROR:39:02:' and smart moto says load failed.. what shud i do for this??? |
whats the procedure to unl;ok kp500 | peter002 | FuriousGold | 9 | 10-31-2012 13:36 |
What is the procedure to find the pinout of d6000? | edermix | SpiderMan | 11 | 11-13-2009 07:35 |
i want to know what is the procedure to change 5300 flash ic? | hooi76 | Nokia Hardware & Hardware Repair | 0 | 06-30-2009 05:32 |
whats the procedure to change the imei in w580 | peter002 | DreamBox | 2 | 03-10-2009 12:10 |
I Need The Procedure To Unlock A E1 With The Smart Clip | suburvio | Motorola P2k | 1 | 01-24-2006 09:36 |
