02-26-2010, 13:25 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | when i flash v3xx time out err Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 io timeout Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 io timeout Searching for phone... no phone found Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.02 io timeout when fone power on . show boot loder bootloader 03.2 sw version R26111LD_U_96 71.95R and after sending boot show critcal err DEA1 how to fix... before flash .. mobile is on .. just only sp lock copmlete procedure prepare smart tp ... in end progress... time out prob |
02-26-2010, 13:48 | #2 (permalink) | |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ Tanveer_city01, Quote:
If you have connected the set in powered on condition, then backup of the phone's firmware version was automatically saved. Please run unlock procedure via Prepare cycle once again. During last stages of the Prepare Smart TestPoint procedure backup copy will be automatically detected and SmartMoto will suggest to restore it. If the phone was connected in flash mode, perform Prepare Smart TestPoint procedure and flash the handset with the same firmware version like the set originally had or higher one. Best Regards GSMServer team | |
The Following User Says Thank You to GSM_Support For This Useful Post: |
02-26-2010, 21:47 | #3 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 43
Member: 120908 Status: Offline Thanks Meter: 38 | if i have v3xx dead can that detect with smart moto with test point in above that phone be flashesd in s flash can v3xx make to sblank how that phone conect to smart moto if that dead |
02-27-2010, 09:58 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ jufong, If the phone is completely "dead" and can not be detected by the PC or any software, nothing can be done to it at the moment. Best Regards GSMServer team |
03-01-2010, 07:53 | #5 (permalink) |
Member: 259397 Status: Offline Thanks Meter: 76 | Did you connect the phone in powered on mode or it was in flash mode? If you have connected the set in powered on condition, then backup of the phone's firmware version was automatically saved. Please run unlock procedure via Prepare cycle once again. During last stages of the Prepare Smart TestPoint procedure backup copy will be automatically detected and SmartMoto will suggest to restore it. If the phone was connected in flash mode, perform Prepare Smart TestPoint procedure and flash the handset with the same firmware version like the set originally had or higher one. thnx gsm server team .. my prob is solved by above procedure once again thnx |
problems when flashing v3xx... | SicilianBoy | Smart-Clip | 1 | 11-01-2008 09:35 |
error time out when download form supported area | chris2007 | Smart-Clip | 1 | 06-11-2008 07:12 |
how to reset time out when unlock sim | copden | HTC & PDA WM( With Touchscreen) | 0 | 02-10-2008 19:31 |
Mot t720i problem,erase flash error time out!!! | sebastijan | Motorola P2k | 1 | 01-30-2004 15:54 |
MSS Flash Time-Out | valka | Motorola P2k | 14 | 01-25-2004 18:32 |
