08-10-2007, 07:28 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: in gsm world
Member: 269885 Status: Offline Thanks Meter: 50 | v3i flash problem,urgent help needed boot version is 0A.30 firmware is R479-G-08.B4.34R it come to for unlocking,it came its current state after unlocking by ultima box,now i flash it wid smart clip but failed,recive the following log SmartMoto 2.27 S-Card: xxxxxxxxx Smart-Clip dongle, v 1.40, assigned Smart-Clip: xxxxx000x Europe, initializing... OK Clip serial: xxxxx0006, version: 3.19, initializing... OK Searching for phone... could not get USB descriptor Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... ST - M30L0R8000B0 Reading flash id/2... ST - M58LR128FT, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,K1,Z3 Hardware IMEI: 353623013243540 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 353623013243540.mbk" Writing flash section 8 of 8... 100% (67.5 Kb/sec) Flash completed! Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... 0x90 - 0x0090, chip unidentified Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,K1,Z3 Hardware IMEI: 620C6EF20F3D672 IMEI OTP status: locked Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... 0x90 - 0x0090, chip unidentified Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,K1,Z3 Hardware IMEI: 620C6EF20F3D672 IMEI OTP status: locked Incomplete chip identification, restore & write functions unavailable wat should i do for this,urgent help needed |
08-10-2007, 07:48 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ burraq, "Reading flash id... 0x0090-0x0090". Incomplete chip identification means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
K800i UNLOCK PROBLEM URGENT HELP NEEDED.... | joebastian | SETool2 | 9 | 07-22-2008 15:07 |
u600 unlock problem urgent help needed | burraq | UST Pro II | 3 | 07-16-2008 20:19 |
6300 keypad hang problem .. urgent help need | mysticalboy2001 | Nokia Hardware & Hardware Repair | 0 | 06-14-2008 16:58 |
CU720 unlocking problem....urgent help needed... | harim_1981 | VygisToolbox | 8 | 06-05-2008 15:46 |
v3i flash problem,urgent help needed | burraq | Motorola P2k | 5 | 08-17-2007 11:39 |
