12-25-2008, 15:29 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ traxgsm, Z8 can be flashed with the *.pcf flash files using SCout flasher and S-Card or SCout dongle. *.pcf flash files available at the www.boot-loader.com More detailed information regarding SCout flasher can be found at the www.scoutdongle.com Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-25-2008, 15:46 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ traxgsm, What firmware version did you use to flash the set? Show us full log file, please. Also, please explain in more details what is wrong with the handset. Why you want to flash it? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-25-2008, 16:00 | #5 (permalink) |
No Life Poster Join Date: Nov 2007 Location: tunisia elmanar sfax
Member: 636518 Status: Offline Thanks Meter: 175 | the phone dont start up ..it only show "motorolla" and it reboot....in boot mode it show " boot loader A3.CC".... i try to flash it with scout flasher with pcf firmware but always same prob ""Phone is not compatible with multi-interface super-file. Flash failed" |
12-25-2008, 16:09 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ traxgsm, Did you try to flash the phone with the *.pcf files from the www.boot-loader.com? As can be seen from the log file some *.sbf file was used. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-25-2008, 16:11 | #7 (permalink) |
Member: 636518 Status: Offline Thanks Meter: 175 | i use 3 pcf files from www.boot-loader.com what about this erreur :Flash failed Memory address 0x05001294 access violation at 0x7C9218D0 ????? |
12-25-2008, 16:38 | #8 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | You are trying to flash V8 with flash file for Z8. It's a very bad idea... In order to flash your V8 it has to be detected by the program normally... |
12-25-2008, 16:53 | #10 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Your phone is like this? http://www.christdeal.com/images/Motorola-RAZR2-V8.jpg If yes, then you have to flash it with pcf / V8 flash files. |
12-26-2008, 08:31 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ traxgsm, So what phone model, exactly you have? Is it V8? If yes, do you know what V8 you have, 512Mb or 2Gb? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-26-2008, 11:50 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ traxgsm, Please post a photo of the handset here. Also, specify what firmware versions did you try to flash into it. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-26-2008, 12:08 | #15 (permalink) |
Member: 636518 Status: Offline Thanks Meter: 175 | i'v try to flash it with 9 pcf firmware from www.boot-loader.com but no luck..but always same problem:Flash failed Last edited by traxgsm; 12-26-2008 at 12:15. |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
Z8 flash problem plz help | rajabrotherscom | Scout | 12 | 03-07-2010 01:12 |
z8 flash problem | mroa | Smart-Clip | 4 | 02-10-2009 08:33 |
