10-15-2004, 00:35 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: on air Age: 46
Member: 5921 Status: Offline Thanks Meter: 5 | About SagMaster Infineon who can help me please let me know! it's urgent! thank you!!! |
11-05-2004, 12:36 | #4 (permalink) |
No Life Poster Join Date: Dec 2002 Location: ...where eagles fly...
Member: 19267 Status: Offline Thanks Meter: 101 | Pls some one help me I bought x5 pcs of infineon flasher form gsmserver all could not flash any phone yet unlock always gives out a BIG BLANK COVERING ON MY PC or this ERROR MESSAGE WHEN i USED FRIENDS FLASH SW SW = DI4,6J: 070802 1733(21) PID = D2 C2 C1 E4 F3 3E D1 C5 BE 14 ED 60 IMEI = 350800351494652 Flash(0): AMD 29LV160BT 16Mbit Flash(1): Sharp LH28F800BGH - B 8Mbit Error in EEPROM Structure Aborted! (1) WHAT DO i DO ? |
11-05-2004, 15:38 | #5 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 17330 Status: Offline Thanks Meter: 15 | 1. Install in Drive C 2. Each dongle has its own eeprom file like xxxxxxxx.EEp. where xxxxxxxx is your dongle's serial number. The file must be obtained from gsminfo with your s/n. Go to support page and fill-in the registration form. Then you can obtain this file Thereafter, put the eep files in the same folder as your prog. I hope your dongles are not cloned. |
11-06-2004, 13:12 | #6 (permalink) |
Member: 19267 Status: Offline Thanks Meter: 101 | yes but the dongles I bought from gsmserver can gsminfo give the eep[rom file and which support will I go to cos I was told to go to to sagmaster to register which i did and was given user name and pass yet no progress. |
11-06-2004, 13:33 | #7 (permalink) |
Member: 17330 Status: Offline Thanks Meter: 15 | http://www.sagmaster.com/ Use your log in and psw for the infineon page, then you can download the file. Each dongle you bought will have different eep file. And you may have to have different log in name and psw for each dongle |
11-06-2004, 13:56 | #8 (permalink) |
Member: 19267 Status: Offline Thanks Meter: 101 | oh boy done dz more than 6x yet tells me wrong pass even with the one supplied copied and inputed manually thats why I had to cry out on the forum. same prob with x3 pcs now retyurned to me |
Needed: 1 Piece Sagmaster infineon | Khryssis | Wanted Products | 2 | 11-13-2005 13:13 |
Old and CHEAP Sagmaster Infineon | livewirecebu | Wanted Products | 0 | 07-01-2005 13:32 |
about SagMaster Infineon dongle pb pls help??? | proxy_gsm | SagMaster Team OLD Products | 3 | 08-04-2004 07:47 |
SagMaster Infineon 00.05 start sale | gsminfo | SagMaster Team OLD Products | 14 | 07-29-2004 23:28 |
About SagMaster Infineon 00.05 ??? | proxy_gsm | SagMaster Team OLD Products | 8 | 07-25-2004 16:21 |
