11-28-2006, 12:22 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: ..:::algEria::..
Member: 198673 Status: Offline Thanks Meter: 8 | box can't repair -- ) i have device not found problem and i try to fix it with SM_II_Rebuilder_v1.4 after finished the operation and make update and registration sagmaster box always have Device Damage ===== log ==================================== Lpt Port : 0x378 Status : Device Damage! Serial : 4BEDXXXXXXXXXX Connecting ... OK. Please Wait... Your going to upgrade SagMaster Box. ( First time connected will by ask for Registration - Required to Update box.) Good Luck. Regards, SagMaster Team, Customer Service. Please Wait ... >>>>>>>>>__ Succesfull. Lpt Port : 0x378 Status : Device Damage! Serial : 4BEDXXXXXXXXXX The End. Connecting ... OK. Please Wait... The End. ======================================= how can i fix it...please help br |
12-02-2006, 11:21 | #5 (permalink) |
Member: 198673 Status: Offline Thanks Meter: 8 | now i have this Lpt Port : 0x378 Status : Device Damage! Serial : 4BEDXXXXXXXXXX Connecting ... OK. Please Wait... Ther's problem with upgrade your SagMaster Box Please contact with resseller or [email protected] Regards, SagMaster Team, Customer Service. The End. thanx |
12-06-2006, 19:43 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | i have same problem as u aftre rebulid box still have problem with err in box and box damaged i don't thik that is tha Atmege cos rebulder test the atmega and found it good the solution is here "Gsminfo" |
12-07-2006, 11:11 | #8 (permalink) | |
Member: 198673 Status: Offline Thanks Meter: 8 | Quote:
===================== Hello !!! You have problem with upgrade SCDR 2 box . Your dongle have broken atmega chip IC Change atmega IC chip TYP 32L to new one and use online repair system from www.sagmaster.com download section if you dont know how change this chip send back dongle to reseller for exchange this chip to new one . Best Regards SMT ===================== i think that is my last solution i m waiting for a chip to tested it br | |
12-07-2006, 23:39 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Cameroon Age: 52
Member: 163755 Status: Offline Thanks Meter: 126 | impossible to fixe new SCDR II Good day Can't they not make the atmega 32l avelable to the reseller because is very difilcult to see it. Pls gsmifo make it avelable for your customer |
12-07-2006, 23:40 | #11 (permalink) |
Member: 163755 Status: Offline Thanks Meter: 126 | impossible to fixe new SCDR II Good day Can't they not make the atmega 32l avelable to the reseller because is very difilcult to see it. Pls gsmifo make it avelable for your customers |
12-13-2006, 21:54 | #14 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Serbia
Member: 9165 Status: Offline Thanks Meter: 0 | When i start new version 23.01a (before that dongle workng ok), i get: - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - MSG: NOT READY, PLEASE WAIT FOR PREPARE DATA! What happend? |
12-14-2006, 17:13 | #15 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | to all please use latest version SCDR 2 V 23.01 Released http://212.85.119.125/inne/SCDR_II_V23.01_setup.exe SagMaster V 18.01 Released http://212.85.119.125/inne/SM_II_v18.01.setup.exe B R SMT |
cyclone box can't change to main mode [SOLVED - Thanks HRCO] | banalven1 | Cyclonebox | 5 | 03-29-2010 09:34 |
lg mg 110 infinity box can't repair imei | devil6684 | Infinity-Box | 2 | 04-09-2009 16:48 |
my box can't repair | zablon | Universalbox | 2 | 05-14-2008 20:52 |
multi-box can't unlock or repair sendo phones | vandal | Multi-Box | 3 | 05-24-2006 02:28 |
