Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SagMaster Team OLD Products
Old 05-07-2007, 20:41   #1 (permalink)
fingusio's Avatar
Member: 16927
Sonork: 100.1592866
Problem with unlock Sagem MyX5-2v
I have Sagem MyX5-2 for unlock. Phone is new on gwaranty
Sometimes when i press Detect Phone i have only:
Found Phone, Phone Info:
- Product Code: 252201545
- Board Type: m62+
Second time when i press Detect Phone:
- Phone Type: myX5-2v GPRS
- Phone FW: KB3,ZJ: 241005 1529
- Phone HT : 75 41 01
- Phone IMEI: 35610xxxxxxxxxx
- Phone Code: 0000 (inactive)
- Board Type: m62+
- MCP Flash ID: 00 01 22 7E 22 21 22 01
- Chip(0): AMD S29GL128NH/L 128Mbit
Then when i press Read Codes:
- ERROR: CHECK TEST POINT!
All tp on board was cleared. When i don't connect TP adapter on board and press Read Codes and when i see check the test point i can again detect phone. I test it on SCDR2 and SMTi.
Next when i press Detect Phone:
- MSG: PHONE NOT FOUND!
When i want connect again to phone i must reconnect baterry.
any sugestion?
br,
fingusio
Old 05-08-2007, 12:43   #2 (permalink)
DZStorm's Avatar
Member: 160204
Sonork: 100.113150
@fingusio
As you see that your phone is detected by software & info readed too , you have just one error "ERROR: CHECK TEST POINT!" , check again your test point , if not try to clean it ,then re check again !
If not , you can use "direct wires" option too .
Old 05-08-2007, 12:58   #3 (permalink)
fingusio's Avatar
Member: 16927
Sonork: 100.1592866
No no.
I ask GSMINFO, and he told that sometimes MyX5-2v have CPU from MyX6-2. Solution for unlock is same like X6-2
br,
fingusio
Old 05-08-2007, 15:49   #4 (permalink)
gsminfo's Avatar
Member: 23714
Yes its true
SMT
Old 05-08-2007, 15:56   #5 (permalink)
fingusio's Avatar
Member: 16927
Sonork: 100.1592866
We have only hope that SagmasterTeam found easier solution for unlock new Sagems....We believe in you !!
br,
fingusio
Old 05-08-2007, 16:56   #6 (permalink)
DZStorm's Avatar
Member: 160204
Sonork: 100.113150
@fingusio
That's a pleasure to "Sagmaster Team" to do the best for the best
problem with unlock sagem my500c harkishan singh FuriouS TeaM Products 2 10-23-2009 13:02
problem with unlocking Sagem (Vodafone) 226 Boshko_Alfa Infinity-Box 10 09-13-2009 15:42
probleme with unlock sagem 225x kakaomar SMTi 3 12-26-2008 09:54
problem with unlock sagem MyXT. i have phone id. PSG ARM9 BASED M62 / M62+ 3 10-28-2005 16:53
Help unlock sagem MyX5-2v Albinas ARM9 BASED M62 / M62+ 0 09-08-2005 20:13
Page generated in 0.23578 seconds with 11 queries
