01-10-2007, 19:33 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 278363 Status: Offline Thanks Meter: 0 | Sagmaster Help Plz , Urgent!!! Help plz, SAGMASTER TEAM - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - ERROR: SERVER CLOSE CONNECTION! |
01-11-2007, 15:38 | #6 (permalink) |
Junior Member Join Date: Nov 2003 Location: Poland Age: 41
Member: 43824 Status: Offline Thanks Meter: 3 | I have the same problem - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - ERROR: SERVER CLOSE CONNECTION! |
01-13-2007, 12:13 | #12 (permalink) |
Member: 43824 Status: Offline Thanks Meter: 3 | Latest exe wouldn't helped me becouse when i run it he couldn't find Client_tool.exe. So I put it to directory where is program installed and replaced it. Then it started working and later i musted run client tool to upgrade box and that's it. Ofocurse when i run client tool i musted again put all registration numbers and names. It's all working :-) |
L6 On Bootloader - Need Help Plz! Urgent!! | khem | Motorola Hardware Repair | 8 | 01-03-2009 18:25 |
w200i country lock help plz,, urgently | vinkle | Cruiser Suite | 1 | 10-24-2007 11:10 |
L6 On Bootloader - Need Help Plz! Urgent!! | khem | Ultima Box Light | 5 | 05-25-2007 06:26 |
help help help help plz urgently | ra_in_bow | Nokia Hardware & Hardware Repair | 0 | 01-26-2007 09:39 |
