SCDR II Update problème _ Plz help Plz whit SMT ClientTool sed Update succes but whit the latest soft sed Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - MSG: PROBLEM REBUILD DEVICE! - MSG: S/n: XXXXXXXXXXXX ERR: 101 Plz what i must do ? |
contact gsminfo in pm and send him dongle serial and he will fix it for u i had the same problem |
don't need to change chip AtMega32 ? if no in wich case we need to change it case i've see in this forum the section for change AtMega32 ? |
Now it show me Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - ERROR: SERVER CLOSE CONNECTION! What dose it mense ? |
my friend, i have similar problem as u had, but then i've run update tool again, and surprised to see new re-registration of my scdr2 box, filled in requirement in the box as usual, then i re-run program again, and now its working. good luck mate. |
i have same probplam SCRD2 Plz.fix. thank:mad: |
- ERROR: SERVER CLOSE CONNECTION! please check PC and internet connection 100% prblem from this site Please change internet connection maybe change PC SMT |
New error message again : - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - MSG: PROBLEM REBUILD DEVICE! - MSG: S/n: XXXXXXXXXXXXXX ERR: 100 i've run the soft lot of times, one time it's error 101, other time it's error 100 and error server close connexion, Plz Sagmaster team HELP :mad: just explaine me whats the probleme if i must wait or change the AtMega32 or what ? (I've send you dongle S/N in pm) |
@Métal_gsm Please change PC Its strange situation you have all time some errors dont know why maybe some problem with connection or PC change please and try again SMT |
affter change PC same prob. - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - MSG: NOT READY, PLEASE WAIT FOR PREPARE DATA! |
@janjaroen I see your problem now start now latest exe please post result here SMT |
same prob whit last exe (23.01a) - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - MSG: NOT READY, PLEASE WAIT FOR PREPARE DATA |
i have the probleme: Now it show me Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - ERROR: SERVER CLOSE CONNECTION! when ichange the pc : i get best result & probleme resolved. it apear second window of sagmaster upgrade tool & terminate the next step. dongle rebuild. thx gsm info. mb: my first pc is: p4 1.6GHz & the second one is P4 2.8GHz. |
same problem for me - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Ok - MSG: DEVICE READY TO REBUILD! Rebuilding Device: - Write Flash ...Ok! - Write Flash ...Ok! - Write Flash ...Ok! - MSG: NOT READY, PLEASE WAIT FOR PREPARE DATA! butI'm still waiting since last week but nothing hapens, what to do? |
I'm sorry but it not PC or Internet connexion probleme, I've trie in 3 Pc's whit diffrent config and difrent Internet Connexion (Diffrent Operators ADSL 128KBPS and 256KBPS) always same error message "Error 100" some Times "Server close connexion" :o |
