Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2004
Member: 55766 Status: Offline Thanks: 450
| Still getting error in run test 3 on smII Despite doing all youve told me to do Sagmaster team including replacing Atmega32L ic I'm still getting error on run test 3. If I run client tool it says device not found. I tried with latest version 18.07R but still the same. - ERROR: DEVICE DAMAGED, NEED REBUILD! Looking For AtMega32 ...Found Test Device: - Run Test 0 ...Ok - Run Test 1 ...Ok - Run Test 2 ...Ok - Run Test 3 ...Error Any other suggestions? this device was working ok befor update. |
| | #2 (permalink) | |
| Quote:
I Think problem was to do with voltage supplied by usb. I was using hub with seperate voltage, I tried a different usb port on my pc but still got the same error (despite changing Atmega32) but today I also tried in different usb port on same PC and it updated ok. Maybe originally it was Atmega as I'd tried on different PC but it seems problems can also be due to usb port as well and maybe not always Atmega replacement needed. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Getting Errors In Bb5 Unlocking | sakisager | Nokia Base Band 5 ( BB-5 ) | 1 | 05-14-2007 13:42 |
| Run Test 3 freeze | Ionel | SagMaster Team OLD Products | 3 | 09-21-2006 11:49 |
| Problem solved:if you get error in some commander! | haveri | Redbox | 2 | 05-08-2006 18:02 |
| GX15 get error in flash file system | galaxi | Sharp | 1 | 11-02-2005 16:12 |
