Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SagMaster Team OLD Products
Old 01-03-2007, 22:20   #1 (permalink)
Member: 169579
when scdr2 able to unlock MyX1-2?
can SMT tell me when likely scdr2 box able to unlock myX1-2?
Old 01-03-2007, 22:58   #2 (permalink)
giorgi2002's Avatar
Member: 12524
http://www.sagmaster.com/tp/index.php?pSel=30
Old 01-04-2007, 21:02   #3 (permalink)
Member: 169579
Originally Posted by giorgi2002 View Post
brother, what model to select to unlock this myx1-2 with scdr2 box?
only myx-1, myx-1w, myx-1t, myx-1wt available. so which one to choose.
cheers
Old 01-04-2007, 21:22   #4 (permalink)
giorgi2002's Avatar
Member: 12524
friend conect phone and click detect phone
Old 01-04-2007, 21:40   #5 (permalink)
Member: 169579
ok mate, it used myx-1t, and unlock DONE!, but when insert sim card, is dsiplayed 'SIM LOCKED', why?
Anything else to press, ro redo unlocking process again.
hear from u asap.
cheers
Old 01-04-2007, 23:59   #6 (permalink)
giorgi2002's Avatar
Member: 12524
try again read code and enter manual
Old 01-05-2007, 01:48   #7 (permalink)
Member: 169579
ok, with sim card - displayed 'Sim Locked', so how can i entre at this point?
if without sim card, what to press in order to enter codes then?
hear from u asap pls
Old 01-05-2007, 02:18   #8 (permalink)
Member: 169579
Found Phone, Phone Info:
- Phone FW: JF3,VI: 130106 1033
- Phone HT : 02 00 02
- Phone IMEI: 355982000557686
- Phone Code: 00000000 (inactive)
- Flash ID: 00 01 22 36
- Chip(0): AMD 29DL161DT 16Mbit
- MSG: UNSUPPORT STANDALONE HASH TABLE!
Get Code from server ...Success
- L00 hex: 0x8B49ABD2 dec: 23368611-38
- L40 hex: 0xCB89AB12 dec: 34147970-74
Clear Net Code...Done!
so how to entre which code and how in ref to question above?
Old 01-05-2007, 16:04   #9 (permalink)
gsminfo's Avatar
Member: 23714
USE DIRECT OPTION
for unlock thisphone
SMT
Old 01-07-2007, 20:35   #10 (permalink)
Member: 169579
Originally Posted by gsminfo View Post
USE DIRECT OPTION
SMT
only DIRECT option is for write FLASHING. Pls consult again, u meant to flash phone in order to unlock it?
Old 01-08-2007, 16:51   #11 (permalink)
gsminfo's Avatar
Member: 23714
USE "Clear Net Lock '
its all
SMT
Old 01-09-2007, 05:16   #12 (permalink)
Member: 169579
its all
SMT
Sir see log below obtained from unlocking the above model. After DONE!, insert sim card, it said 'SIM LOCKED', why? See result below said NET LOCK cleared, but still SIM LOCKED?
pls any solution? any other option?
phone stil SIM LOCKED!!!!!!
hear from u now pls.
Old 01-09-2007, 11:34   #13 (permalink)
gsminfo's Avatar
Member: 23714
@ktele
if you have simlocked without sim card
no solution yet
Old 01-09-2007, 11:38   #14 (permalink)
gsminfo's Avatar
Member: 23714
@ktele
Send me box sn via ICQ or SKYPE
SMT
Old 01-10-2007, 02:21   #15 (permalink)
Member: 169579
@ktele
no solution yet
after unlocking, it's 'sim locked' when sim is inserted only,
when we able to unlock 6220c rm-328 himanshu taldar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 07-24-2009 12:03
when i able to unlock nilan Easy-Unlocker 3 12-17-2008 20:08
how to unlock myx1-2 twin chris2007 SMTi 6 09-16-2007 02:04
How to unlock myx1-2 trio ? Triminity ARM9 BASED M62 / M62+ 1 10-18-2005 06:57
Is it possible to unlock MYX1-2 with sws-sag ? gsmnice Redbox 7 08-26-2005 12:43
Page generated in 0.34400 seconds with 11 queries
