E606 set off when try to camera on Hi :rolleyes: i have a Nec E606 But when i try to open its camera . the set is off. i reset phone and memery . i also unlock it. but same . i think its software problem .or its camera shortage, if that software then i havnt its flash file . any one know what is the matter and its software or hardware . if its software . then where can i find the flash file. Br Kuku |
i have the same problem if anyone have a solution please help us ! |
i solved the problem yes its some earth (shotage )in points check it with out speaker and other Br Kuku |
Hello man be aware out from this problem because i solve it it is problem of your stripss of camera there is two strips of youurs cams please push them or simply open its cobver there is two strips in the down area of your camera please push them all thing will be rght if any confusion please contact me at I WILL DO IT ABDULLAH ALTAF www.layyah-forum.com 03008764201 layyah pakistan |
Yes you are right bro I have one E606 with same problem, when I start camera phne shut down I tested totay and it work 100%% only push this two strips an all will be fine |
please explain with diagrams.i have one on my hands now with same problem |
u will see strips...attach with jacks press them.put out and take again ...or change.. problem will solve |
