Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > NEC
Old 12-31-2005, 00:01   #76 (permalink)
Member: 142704
Hello USB cannot help you when you want to unlock nec 606 you need a comport cable that carry test wire here is the link to see your test point not cut just solder http://www.unlockeasy.com/modules.ph...nload&cid=7 4
100% solution
no more problem here the solution
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitterStumble this Post!
Old 12-31-2005, 15:32   #77 (permalink)
shoaibk7's Avatar
Member: 145000
thanx for ur reply but the link not working plz post again and help me i really need ur help thanking u
Old 01-01-2006, 15:22   #78 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
here is the link
http://www.unlockeasy.com/modules.ph...titleA&show=10
Old 01-03-2006, 17:42   #79 (permalink)
shoaibk7's Avatar
Member: 145000
thanx for the link but can anybody help me how to unlock and what should i do step by step .... thanx for any type of help
Old 01-05-2006, 09:15   #80 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
software works in win 98 only run the loader and computer will restart then again run loader select mobile and comport and read codes put codes in mobile and enjoye
step 1
connect any 3g phone with out battery and install the driver and check the com in control panel
step 2
read the codes and enter in it
br
abdul majid
Old 02-14-2006, 04:50   #81 (permalink)
Siemens man's Avatar
Member: 3925
hi guys
i can't use nec wcdma v3.1 soft. allways from me ask key. i'm download from unlockeasy.com. please help me to unlock nec e606 new version. furious can't unlock. help me. where i can find free e606 unlocker.
thank you
Old 02-15-2006, 18:50   #82 (permalink)
Member: 3925
help me guys
please how to unlock nec e606
Old 03-30-2006, 12:18   #83 (permalink)
LOUAI2005's Avatar
Member: 192230
hi good solution gsm lab
good job
Old 04-25-2006, 13:42   #84 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
hello
again today i have unlocked my E606 work fine
plzz take a look
br
Gsm Lab
Old 04-25-2006, 14:06   #85 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
here is the easy testpoint
Old 04-25-2006, 17:48   #86 (permalink)
Member: 3925
hi man
this is cracked soft working some nec e606. not most. need good soft for unlock
Old 04-25-2006, 19:06   #87 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
yes!!! man u say right
but i have little good solution for this i got 10 nec E606 network Lock
connect the testpoint and trying to unlock it but show me remove bettery now!
but phone is still lock i have check my another e606 connect testpoint trying
to unlock it's unlocked operation done
so i have read this flash file and write my first phone before i say's u still
unlock and then unlock it with furious cracked work fine
best regards
[glow=red]Gsm Lab[/glow]
Old 04-25-2006, 19:40   #88 (permalink)
freakyass's Avatar
Member: 154522
Arrow it is true or false ???
@gsmlab can i use standart rs 232 cable or usb to serial bridge cable modified by me to unlock nec e 606, so gimme da solution.... best regards, indonesian unlocker
Old 06-25-2006, 09:49   #89 (permalink)
shafnashaji's Avatar
Member: 46116
For me I used Philips savy cable with power supply (5 Volt)
And all ok for me.....Also I use needle insted of soldering so for me its fast ....And I did around 60 phones like this.....
So all the best.....
Old 06-26-2006, 18:21   #90 (permalink)
Member: 184739
plz help me nec unlock sim
how to remove simlock / unlock nec e606??? saidgoren NEC 7 06-23-2006 19:17
Unlock NEC e606! How? Maurone NEC 25 04-30-2005 08:56
I need unlock NEC e606 Elian NEC 5 09-05-2004 21:03
Need unlock Nec e606 aliwali NEC 8 09-29-2003 07:30
UNLOCK NEC e606 NELIX Phone Unlocking Codes & Maps 0 08-27-2003 14:25
Powered by Searchlight © 2010 Axivo Inc.
- GSM Hosting Ltd. - 1999-2010
Page generated in 0.11161 seconds with 7 queries
