04-28-2013, 05:39 | #1 (permalink) |
Insane Poster Join Date: Nov 2011 Location: Pilipinas
Member: 1687326 Status: Offline Sonork: 100.1646202 Thanks Meter: 60 | N-04c NEC MEDIAS Docomo Too Many Patterns Attempts DONE!!! [REFERENCE] Model N-04c Nec Medias Docomo Problem Too Many Pattern Attempts! Hard Reset Procedure Phone Must Be Off Press Volume Up + Volume Down + Power Switch Wait Until Download mode appear Then Press Volume Down System Recovery will Prompt Select Wipe Data/Factory Reset Use Volume Down for Cursor And Volume Up for Select Click Yes to delete all user data "but before to confirm it will need password for recovery" here's the TIPS: Code: Take the second digit then the last 4 and last 3 and last 2 in the IMEI then it is the password for recovery Screen Shots enter your 4 digit password will find at the back of phone it will prompt when your password is correct (just click "YES" to reset) Finished Product this 4 digits marked in red must be your password BR, Last edited by Silverstein; 04-28-2013 at 05:47. |
The Following 14 Users Say Thank You to Silverstein For This Useful Post: |
05-03-2013, 20:40 | #2 (permalink) |
Freak Poster Join Date: Mar 2011 Location: abuja
Member: 1537908 Status: Offline Thanks Meter: 11 | Nice information it really work like charm 10000000000000% Tested! the only mistake is the step after recovery, it is actually the ''VOLUME UP'' u need to press b4 u can see the wipe data/factory reset screen, not the volume down. But he did great. Best Regard! |
The Following 3 Users Say Thank You to solutionpearl For This Useful Post: |
09-27-2013, 07:16 | #4 (permalink) |
Junior Member Join Date: Jul 2006
Member: 312023 Status: Offline Thanks Meter: 1 | How did you find this out? I have an NEC terrain that has the same requirement for a passcode. I've tried this method and it doesn't work. I know the Medias is made by NEC as well. Appreciate any guidance, thank you. |
The Following User Says Thank You to hhsfool For This Useful Post: |
12-19-2013, 15:13 | #5 (permalink) |
Freak Poster Join Date: Nov 2007 Location: karachi,pakistan Age: 40
Member: 625563 Status: Offline Sonork: Niceguy Thanks Meter: 40 | how can i found password i triyed 1234.123456.11111111.123456789.0000.00000.00000 but no result what can i do for found my password? |
06-03-2015, 14:28 | #6 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: Jamalpur, Bangladesh
Member: 623873 Status: Offline Thanks Meter: 41 | Quote:
08-01-2015, 23:33 | #7 (permalink) | |
Junior Member Join Date: Aug 2015
Member: 2438121 Status: Offline Thanks Meter: 0 | Quote:
I even know my gmail username and password, and entered that, and it still doesn't unlock. Has anyone managed to recover from too many pattern attempts on the NEC terrain? Thanks. | |
09-03-2016, 20:15 | #9 (permalink) |
Insane Poster Join Date: Feb 2015 Location: Buea, Cameroon Age: 32
Member: 2347074 Status: Offline Thanks Meter: 30 | What you have to do is remove the battery, copy the IMEI somewhere... Then If your IMEI is:0123456789abcde Then your recovery Password is:1bcd |
The Following 4 Users Say Thank You to dspurs For This Useful Post: |
09-03-2016, 20:16 | #10 (permalink) | |
Member: 2347074 Status: Offline Thanks Meter: 30 | Quote:
What you have to do is remove the battery, copy the IMEI somewhere... Then If your IMEI is:0123456789abcde Then your recovery Password is:1bcd | |
