Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > NEC
Old 06-21-2006, 12:30   #1 (permalink)
alvis's Avatar
Member: 87676
Sonork: 100.1589832
Thanks Meter: 110
Nec 606 & 808 Security Code Solution For Free
NOW END THE DRAMA OF NEC 606 & 808 SECURITY CODE ITS ALL FREE FOR EVERY ONE DO NOT SPEND UR MONEY FOR SOFTTHIS IS THE GIFT FROM ALVI MOBILES THIS IS THE CAMMANDS FOR NEC production command
FF E0 E1 40 04 00 00 10 4C 11 FE show serial number
FF E0 E1 40 0C 00 00 10 4C 10 12 34 56 78 90 12 34 56 FE set serial number (16 digit)
FF E0 E1 40 05 00 00 10 4D 00 0C FE show software version
4D 00 0D
4D 00 0E
FF E0 E1 40 04 00 00 10 4C 01 FE show IMEI
FF E0 E1 40 05 00 00 10 4C 13 10 FE show process
FF E0 E1 40 09 00 00 10 00 02 00 60 04 10 00 FE show personal
FF E0 E1 40 04 00 00 10 41 04 FE clear eeprom
FF E0 E1 40 04 00 00 10 41 10 FE clear sram user
FF E0 E1 40 04 00 00 10 41 11 FE clear sram all (acpu sram)
USE CLEAR SRAM USER CAMMAND AND THIS IS THE SOFTWARE WHICH USE FOR CAMMAND AND I ALSO FOR CLEAR EVERY ONE THIS IS THE CAMMAND ONLY COPY PAST THIS ONE FF E0 E1 40 04 00 00 10 41 10 FE THIS IS THE PINOUTS FOR PHONE AND THIS IS THE LINK FOR SOFTWARE http://www.allnec.info/download.html
I UPLOAD TWO JPG OF SOFT AND CABLE USE SHARP GX30 COM CABLE AND THE PHONE MUST BE ON
THIS IS THE ADDRESS AND PHONE NUMBER SHOP NO B1 REGAL CENTER HALL ROAD LAHOHER PH NO 0427351202 03214771583
IF SOME ONE WANT THE SOFT FOR FREE PLZ VISIT US
File Type: txt CAMMNADS.TXT (570 Bytes, 2212 views)
Old 06-21-2006, 12:36   #2 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
Thanks Meter: 19
nice to see the solution comments after testing
does gx30 cable work without modification or need modification if yes kidnly write down the number of pin which is not clear in the picture
thanks & regards
Zafar Janjua
Old 06-21-2006, 13:39   #3 (permalink)
Member: 170531
Thanks Meter: 7
hi friend
we test this from yastrday and we said its very good
why delet his post ???
its bad way to work
pleas zfrank look who delete the good post ??....
here we help to work not play or for other delete post other to make money
plaes we want work honorably
thanks alvis for gr8 work
good luck for all
Old 06-21-2006, 13:40   #4 (permalink)
BCcommunication's Avatar
Member: 76456
Sonork: 100.1678368
Thanks Meter: 57
thanx zafer bro for cable information and thanx alvis for solution
Old 06-21-2006, 13:42   #5 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 290
4D 00 0D
4D 00 0E
WOW really great solution i will test it today and post results.
Kashif Khan
Old 06-21-2006, 13:44   #6 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 184
Solution for "default imei insert correct usim" ???
Old 06-21-2006, 13:47   #7 (permalink)
Member: 71045
Thanks Meter: 19
all credit go "alvis"
thanks and regards
Zafar Janjua
Old 06-21-2006, 14:15   #8 (permalink)
.::iRizwan::.'s Avatar
Member: 79937
Sonork: 100.84313
Thanks Meter: 4,670
Lightbulb
Yes definitely the credit goes to alvis for publicized the solution.
Old 06-21-2006, 14:57   #9 (permalink)
GSM_N4H's Avatar
Member: 211652
Thanks Meter: 120
yah this is very good work.
no need to unlock nec E606 by pressing 0000, 0001 ...........9999
just need to send the cammand
can some one tell me
1 which cable is used ?
2 what step is must ?
Thanks ALVIS
and explan how to used ?
Old 06-21-2006, 15:08   #10 (permalink)
alvis's Avatar
Member: 87676
Sonork: 100.1589832
Thanks Meter: 110
change the pinouts of sharp gx30 com cable pinouts are
pin2 is rx from phone
pin3 is tx from phone
pin10 is gnd from phone
phone must be on then copy past the command in the soft and press send button and press c button in phone again and again the phone sounds off for 1 sec thats mean phone code is now 0000 now enter the code 0000 and phone was unlocked
Old 06-21-2006, 15:44   #11 (permalink)
alvis's Avatar
Member: 87676
Sonork: 100.1589832
Thanks Meter: 110
i like to help people but one strange thing happend that i post this solution last night and the super moderater Dr Mobile makes my post in sticky but some one deleted it this post gose on 6 pages but i dont know who deleted my post and whos intersted behind this????
Old 06-21-2006, 15:51   #12 (permalink)
alvis's Avatar
Member: 87676
Sonork: 100.1589832
Thanks Meter: 110
if any body has any problem add me in msn [email protected] i will solve the problem
Old 06-21-2006, 16:10   #13 (permalink)
falak's Avatar
Member: 74749
Thanks Meter: 167
wrong pinout not working
thankx
falak
Old 06-21-2006, 16:27   #14 (permalink)
BMobile's Avatar
Member: 154696
Thanks Meter: 15
Old 06-21-2006, 16:35   #15 (permalink)
alvis's Avatar
Member: 87676
Sonork: 100.1589832
Thanks Meter: 110
falak its correct pinouts plz check ur making it with right way plz try it again
Nec 606 And 808 Free Code.. MobilesDoctor Phone Unlocking Codes & Maps 455 02-20-2012 21:37
Nec 606 & 808 Security Code Solution HELP FullFLASHgSMPH NEC 2 07-20-2006 16:03
NEC 606 & 808 Userlock/Keylock xtreme Main Sales Section 0 03-08-2006 11:04
who want Reall nec 606 and 808 unlocker Faisal_Computer NEC 13 07-29-2005 18:13
Nec 606 And 808 Crt Able Flash File And Test Point Download serova NEC 5 05-09-2004 22:41
Page generated in 0.62149 seconds with 9 queries
