06-24-2006, 07:42 | #33 (permalink) | |
Registered User Join Date: Aug 2004 Location: Hall Road Lhr Age: 43
Member: 76284 Status: Offline Sonork: 1001625595 Thanks Meter: 24 | Quote:
Realy it is called ''running thief ' s *********'' | |
06-24-2006, 08:52 | #34 (permalink) |
Registered User Join Date: Aug 2003 Location: ALGERIA ,DZ
Member: 37521 Status: Offline Thanks Meter: 50 | 100% pinout for Nec E606 E808 serial bable hi brothers here is the correct Serial pinout for Nec E606 ,E808 tested by me today and successed to remove secutity code from one Nec E606 |
06-24-2006, 09:26 | #35 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: china
Member: 170531 Status: Offline Thanks Meter: 8 | Quote:
you test this for unlock network e606??? i have e606 i try every thing with this mobile no way to unlock netwrok if you did this can help? | |
06-24-2006, 10:48 | #36 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Cambodia
Member: 59030 Status: Offline Thanks Meter: 165 | NEC 808 driver? when i connect the sharp cable to NEC 808, pc sees the phone and i try to use the nec606 driver but it didn't work. do you have the 808 driver? please give me links for it, thanks |
06-24-2006, 10:54 | #37 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: rajabrothers communications Age: 43
Member: 155773 Status: Offline Sonork: 1606514 Thanks Meter: 87 | Quote:
but thats pin out same with gx30 cable and not working. br raja | |
06-24-2006, 11:50 | #39 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Quote:
tested on 606 today | |
06-24-2006, 14:09 | #40 (permalink) |
Member: 37521 Status: Offline Thanks Meter: 50 | for "targettelecom" if you want to unlock network of E606 then 1 . use this pinout then use NEC Ferious cracked soft 2 . select COM port 3 . select E606 4 . press "Unlock" I don't test it but it seems work , because I unlocked many NEC phones with this soft test and send result . |
06-24-2006, 14:32 | #41 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | Quote:
BR Kashif Khan | |
06-24-2006, 17:20 | #42 (permalink) | |
06-24-2006, 17:22 | #43 (permalink) | |
may be you have this forum???? | |
06-25-2006, 03:11 | #44 (permalink) |
Member: 59030 Status: Offline Thanks Meter: 165 | i tried to unlock nec 808 with 4digit phone code locked today by following your instruction but it didn't work for me...i used the sharp 3g usb cable, installed proper driver..see phone in modem and com port, one for command port, the other as obex port..so i select com # as command port..the soft seems to communicate with the phone and gave the output of +11bites.... do you unlock with simcard or no simcard inserted? what cable do you use, usb or com? thanks |
06-25-2006, 07:34 | #45 (permalink) | |
try and try will work if not use test solder rx tx on board and then try will work | |
Nec 606 And 808 Free Code.. | MobilesDoctor | Phone Unlocking Codes & Maps | 455 | 02-20-2012 21:37 |
Nec 606 & 808 Security Code Solution HELP | FullFLASHgSMPH | NEC | 2 | 07-20-2006 15:03 |
NEC 606 & 808 Userlock/Keylock | xtreme | Main Sales Section | 0 | 03-08-2006 11:04 |
who want Reall nec 606 and 808 unlocker | Faisal_Computer | NEC | 13 | 07-29-2005 17:13 |
Nec 606 And 808 Crt Able Flash File And Test Point Download | serova | NEC | 5 | 05-09-2004 21:41 |
