Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > NEC
Old 03-20-2005, 16:21   #1 (permalink)
Member: 27932
NEC E313 dead afrer direct unlock
I got NEC E 313 to get rid of simlock, I used Crazy code reader but it didn't read codes. Software inside the phone is V16 so I used direct unlock. After that the phone is dead, but it flashes itself and works normally in service mode when pluged. have you had a similar problem? Maybe you could give me some tips how to solve it? Would be really greateful!
Best regards! rogals79
Old 03-20-2005, 16:55   #2 (permalink)
Member: 38207
If you have an original crazzy flasher + PL lang you should have a solution for dead e313 (after flashing, not unlocking, but I think that the fixing procedure sould be the same).
You have to :
- flash the phone third version of flash (setup_313_pl_ver3.exe)
Phone should be working for now, if it does not:
flash english for e228
flash english for 313
flash polish 313_ver3
- if you dont have english flasher you should :
flash polish 228
I didnt test this solution because I didnt get any problem like you, but I think it should be fine. Please post your results here.
Old 03-20-2005, 17:00   #3 (permalink)
Member: 86888
Thanks Meter: 230
Hi
can u tell me. I have registered user but some software i download so he says login and password while I logged.
can u help me.
I will be very thankfull for this act of kindness.
thanks for anticipaiton.
[email protected]
Old 03-20-2005, 20:38   #4 (permalink)
Member: 27932
i tried this way and not work, any another sugestion
Old 03-24-2005, 12:20   #5 (permalink)
Leo140's Avatar
Member: 43076
Thanks Meter: 8
I have one E313,turn onm it show please wait, initialing .. forever
how can I solve this problem
I have flashed it, read code but imei erro
pls help
thank you
Old 11-05-2005, 00:59   #6 (permalink)
danilo_nop's Avatar
Member: 31049
Thanks Meter: 4
I have same problem, any solution?
Old 11-05-2005, 05:49   #7 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
For e-313 I used Cracked pbb nexus V4.0 ! and It unlocked the phone ! And please wait solution is also Repaired by it ! Crazzy is not Good for 313 and 616 Nec models !
Old 11-05-2005, 09:19   #8 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 119
If after direct unlock it had gone dead then.. u should try to repair it's imei with crassy5. Try to repair imei with USB as well as Serial cable. This method has worked for me every time.
Old 11-05-2005, 09:46   #9 (permalink)
Member: 101827
Thanks Meter: 23
pls leave the software here or the link, i have the same set with sme fault,
it will b a great help guys
thnx
Old 11-09-2005, 11:21   #10 (permalink)
Member: 126806
My e313 can not charging battery but other functons are right.
Please help.
Old 11-09-2005, 11:29   #11 (permalink)
Member: 126806
I have NEC 313 and my mobile not charging to battery.
All other functions are right and working.
pls help
thank you
[email protected]
Old 11-09-2005, 11:34   #12 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 119
pls help
thank you
Ka[email protected]
Did u ever look at the thread title???
It is about a phone that gone dead after direct unlock.
AND here you crying twice for your phone not being charged.
It is purely a hardware problem. Check charging socket. Clean it. IF not compare the phone with a good one and check where you are missing the perfection. OK
Old 11-11-2005, 00:58   #13 (permalink)
danilo_nop's Avatar
Member: 31049
Thanks Meter: 4
how? it only connect whit usb, but give error, if i try more it get win crash
btw it work for 616...
in nec smart tool21 it give imei 000000000000 and cant repair it too
I have 2 313 flash and 1 288 but phone is still dead
E313 Dead After Direct Unlock With Crazzy. ales6orah NEC 0 01-12-2007 20:15
NEC E313 dead after downgrade... HELP!!! MaDMaN666 NEC 25 04-01-2006 15:55
NEC e313 dead!!! Please HELP!! Nickelodeon NEC 9 10-25-2005 15:06
NEC E313 dead after using ATOM FIRMWARE help is at hand! paulisthebest NEC 1 08-01-2005 18:06
NEC e313 dead after flashing pali Phoenix Black Box 10 06-08-2005 21:07
Page generated in 0.40708 seconds with 8 queries
