Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > NEC
Old 03-03-2005, 10:54   #1 (permalink)
Member: 57464
NEC E313 dead after downgrade... HELP!!!
How to E313 live now after downgared. Sorry for bad English.
Old 03-03-2005, 11:33   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,567
U used Uran or Atom for downgrade !?
Old 03-03-2005, 11:43   #3 (permalink)
Member: 57464
i don't have this information... I want repaired this phone for "power on"
Old 03-03-2005, 11:47   #4 (permalink)
Member: 15022
Sonork: 100.53452
Angry
Use then ATOM flasher ... it should fix it unless is was killed by some unlocking soft. Dont ask me from where to get it ... do a search on forum and u will find links.
Old 03-03-2005, 11:48   #5 (permalink)
Member: 57464
For fleshing the phone no batary or yes?
Old 03-03-2005, 12:04   #6 (permalink)
Member: 15022
Sonork: 100.53452
Angry
No battery, modified usb cable.... Next time use search.
Old 03-03-2005, 12:25   #7 (permalink)
Member: 57464
For flashing 10-15 minute then restarted computer... What that?
Old 03-03-2005, 12:36   #8 (permalink)
Member: 15022
Sonork: 100.53452
Angry
MAN USE ATOM FLASHER !!! THATS URAN FLASHER ... FLASHING TAKES 40MINS.
Old 03-03-2005, 16:56   #9 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
in simple words flash your phone with 228 firware. your phone will be alive again but your camera will be upp side down
and like HACK3R2K said just try to search more there are so many posts about 313 being dead after flashing
br
Old 03-03-2005, 17:19   #10 (permalink)
Member: 100820
br
if u flash 313 nec with 228 u cant upgrade him... for upgrade unlocked phone u can contact me: [email protected]
Old 03-03-2005, 18:15   #11 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
THE ONLY PROBLEM WITH 313 IS THAT TO DOWNGRADE IT U HAVE TO FLASH WITH 228 FIRMWARE AS WHOEVER FLASHED WITH 313 IT SIMPLY WENT DEAD
NOW WHOEVER HAS DOWNGRADED IT WITH 228 FIRMWARE TO UNLOCK IT THEY CAN'T UPGRADE IT
BUT I THINK U STILL CAN UPGRADE IT. BIT LONG PROCEDURE
DOWNGRADE WITH228 FIRMWARE, UNLOCK IT FLASH IT WITH 313 FIRMWARE THE PHONE WILL BE DEAD
BUT THEN UPGRADE IT
DO U THINK THIS WILL WORK????????
Old 03-03-2005, 18:27   #12 (permalink)
mtony969's Avatar
Member: 24552
Thanks Meter: 13
If you payed for correct soft not rip off of Spear no need to downgrade to open the phone .
Old 03-03-2005, 19:14   #13 (permalink)
Member: 15022
Sonork: 100.53452
Angry
Right m8. But in the end if he broke it we must give some hints for repair if he's lazy enough to search.
Old 03-03-2005, 19:15   #14 (permalink)
Member: 100820
BUT THEN UPGRADE IT
Hmmm u have solution to flash normal 313 firmware???
Old 03-03-2005, 22:25   #15 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
and there is no gauranty that if sombody uses spears software then he will have never problem with his phone
software bugs can happen anytime m8 so we can't exclude flashing from unlocking. and mor we experiment with flashing results better for all of us
br
nec n341i dead after unlock help mohamedsamir_04 NEC 4 01-01-2009 03:45
NEC e313 dead after flash vishalmadhvani NEC 16 11-04-2005 06:19
nec e313 dead after flashing gsmservices NEC 2 10-24-2005 16:02
NEC E313 dead after using ATOM FIRMWARE help is at hand! paulisthebest NEC 1 08-01-2005 17:06
NEC e313 dead after flashing pali Phoenix Black Box 10 06-08-2005 20:07
Page generated in 0.23211 seconds with 10 queries
