07-14-2004, 12:02 | #3 (permalink) |
Junior Member Join Date: Apr 2004 Age: 45
Member: 63287 Status: Offline Thanks Meter: 0 | I assure you this works. 1.Put Non Accepted sim In Phone You Have measaage "Insert Correct Usim" 2.Press Right Key Then key Down you Get " Insert usim Code " or Something Like This be carrefull with Counter you have just 3 Tries 3. Like Unlock Codes Input 8 digit Number got from the NEC code calculator Without *4960 and #4960 Now you are Inside of phone but no network 4. Now First Input #4960*xxxxxxxx# xxxxxxxx-Is Your calculated codes nothing happend but is ok now Input second Code *4960*xxxxxxxx*xxxxxxxx# Again nothing Happend 5. Power Off The Phone and Power On and you have network..... If You try to go in message Or somwhere else and see message "unable To start Apllication" Is Ok just put phone alone some time and all will work This is taken from http://forum.gsmhosting.com/vbb/showthread.php?t=142546 Now rename the attachment to NEC.exe The XXXXXXXX number is the number which the unlocker attached generates. But some say that it could be any random number. Its confusing on this part. But from many of the post which I have seen not only this forum but also in other forums, xxx is a any number you like. But instead testing you can use the unlocker software. But this method works for sure. But a hard fact is after coming to 2g SIM you cannot go back to 3G. Try and post the result. |
07-14-2004, 14:56 | #4 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Grumpy Sod Land
Member: 72327 Status: Offline Thanks Meter: 0 | the calculator is a FAKE. heres a few numbers 12345678 54545453 43468907 all will work. the calculator generates an 8 figure number that is then your password. Why not just make up a password yourself. |
07-15-2004, 00:18 | #5 (permalink) |
Junior Member Join Date: Mar 2004 Location: West Wales
Member: 56254 Status: Offline Thanks Meter: 0 | Sorry to rake over old ground but I'm a bit confused and it's always best to ask then to try and make a mistake. My friend has a e313 on G3 in the UK will this calc work for that, and do I just type in the numbers it generates into the phone and thats it ? Many thanks |
07-15-2004, 09:43 | #6 (permalink) | |
Member: 72327 Status: Offline Thanks Meter: 0 | Quote:
the calculator is a FAKE. heres a few numbers 12345678 54545453 43468907 all will work. the calculator generates an 8 figure number that is then your password. Why not just make up a password yourself. The other info is posted in the first few posts on this forum. try 4960. be aware this'll mess up your phone for good, and just unlocks the sim card. try searching. | |
07-15-2004, 09:51 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 53
Member: 51154 Status: Offline Thanks Meter: 68 | Don't forget its only a temporary unlock as well. It simple relocks the phone to the new sim card, if you change sim cards you have to do the whole thing again. Plus it only works on phones manufactured before March 2004 |
07-15-2004, 09:58 | #8 (permalink) | |
SW ACPU:E21.43.04 CCPU:C623 R06 The march 2004 thing could just be a myth, as its more likely to be a software change that prevents unlocking the sim. | |
07-15-2004, 10:41 | #9 (permalink) |
Junior Member Join Date: Jul 2004 Age: 64
Member: 73345 Status: Offline Thanks Meter: 0 | this didnt work or not explained very wel i insert voda sim mobile says please insert correct usim card. pressing any buttons at this stage does nothing except the emergency button,then password screen comes up ,to disable the usim card lock please enter the lock code, enter first code you suggest says ok but no signal ? then enter other code but nowt switch off then it says same as begining am i missing summin?? i insert the 3 g sim and it now says to disble usim enter card lock code ?? the phone is now goosed any help wud b appriciated.. i have one try left at codes i may wait for update to my redbox..?? |
07-15-2004, 11:00 | #10 (permalink) |
Member: 72327 Status: Offline Thanks Meter: 0 | press "emergency button" enter 112 press send phone will switch to 3g hang up call before it dials 112 enter usim code - usually 12345678 phone will accept your sim this process must be repeated every time you switch on you won;t have access to most features |
05-23-2010, 10:21 | #12 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 247439 Status: Offline Sonork: 100.107912 Thanks Meter: 103 | seems to work on software version SW ACPU:E21.43.04 CCPU:C623 R06 The march 2004 thing could just be a myth, as its more likely to be a software change that prevents unlocking the sim. |
Best offline solution for unlocking NEC e313,e616,e616v | laxxe | NEC | 8 | 12-09-2004 01:24 |
Need help to Unlock Nec e313 ver R1Y.Q | phonefun | NEC | 0 | 08-27-2004 13:13 |
unlock NEC E313 | _viktor_ | NEC | 4 | 08-26-2004 07:36 |
unlocking nec e313 e616 problem | doffbi | NEC | 0 | 08-20-2004 10:44 |
pls answer 4 questions for unlock nec e313 | Tyzzie | NEC | 0 | 06-26-2004 18:25 |
