Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > NEC
Old 11-04-2004, 06:38   #1 (permalink)
Member: 30605
Post nec e606 default imei
hello
i have one nec e606 and need security code .i tray some 3 times and now
apears on dispay phone :
default imei
insert test USIM.
i don t no what to do
pls help me
Old 11-13-2004, 05:48   #2 (permalink)
Member: 30605
no one have the soft? or exist some soft for this model?
Old 11-14-2004, 00:23   #3 (permalink)
mohammad2004's Avatar
Member: 71144
how is imei your phone? im send a unlock code
Old 11-14-2004, 00:25   #4 (permalink)
Member: 71144
how is imei your phone? im send a unlock code |***
Old 11-15-2004, 11:54   #5 (permalink)
krusty.spritz's Avatar
Member: 14045
put a "testcard" in the fone .....the old motorola type......then go thru the menus and reset to default...power it down using the power button and its ok
Old 12-07-2004, 14:35   #6 (permalink)
foony's Avatar
Member: 25110
I have same problem, but when I put MOT TEST CARD i to phone, I can not go in to menu. On display is only batt indicator, 2G icon, and two gray oblongs in bootom corners of display. Any other advice? Thanks much.
Old 12-07-2004, 16:16   #7 (permalink)
Member: 14045
eeprom data is corrupt then....
if it had yes/no on the screen it is just a matter of reseting the checksum by defaults
Old 12-07-2004, 16:48   #8 (permalink)
foony's Avatar
Member: 25110
thanks :-( so there is no solution now to repaire ee data?
Old 12-08-2004, 10:42   #9 (permalink)
Member: 10730
no solution ive tried
when you power up phone keep pressing menu button with moto test card in & you can see menu for only few seconds
Old 12-29-2004, 11:48   #10 (permalink)
Member: 5926
and How to fix this ?
still same problem and seems nobody could fix it
Rak|m
Old 02-05-2005, 22:57   #11 (permalink)
Bohosh's Avatar
Member: 14741
I have the same problem.....any ideas ?????
Old 02-06-2005, 01:47   #12 (permalink)
Slider_Gsm's Avatar
Member: 31018
what is your idea about that probleme
Old 02-06-2005, 01:56   #13 (permalink)
The Repair Shop's Avatar
Member: 307549
can you guys not flash them nec's sorry
Old 02-13-2005, 14:03   #14 (permalink)
Member: 116350
please hellllllllllllllllllllllllllllllllllllllllllllllll lp me i need acomplete soft ware to nece606
Old 03-03-2005, 13:15   #15 (permalink)
djyash's Avatar
Member: 15162
Have got one today same problem .
Any solution .
E606 Default Imei vet_er NEC 6 03-31-2007 17:02
e606 default imei solution patric NEC 0 11-20-2006 17:18
nec e606 default imei SATISH NEC 3 08-15-2006 12:33
e606 DEFAULT IMEI InsertTestUSIM?? pls HELP!! silvershadow70 NEC 1 08-15-2006 12:31
Nec e606 Default imei djyash Redbox 5 03-08-2005 04:23
Page generated in 0.64037 seconds with 11 queries
