Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > NEC
Old 04-01-2009, 22:20   #1 (permalink)
Member: 996425
NEC NP500WS and NEC NP600S: Short-distance projections
NEC Display Solutions expands its product portfolio for the education sector with two new short-throw projectors
Solutions is proud to present to the market two innovative LCD projector models featuring short-distance projection capability. NEC is extending its projector portfolio in the education sector with these new models and is offering an outstanding technology solution to this particular market sector. The highlight of both projectors is their virtual remote control allowing full PC control of all projector functions. The NEC NP500WS and NEC NP600S can project pictures with a diagonal of 60” from a distance of only one metre. This means that presenters don’t cast any annoying shadows nor are they dazzled by the projector itself. The two models are ideal for small rooms and are also particularly suited for meetings and training courses where interaction between the participants is best undertaken directly in front at the whiteboard.
The unique Virtual Remote function allows all the projector settings to be directly computer controlled using the VGA cable. It can simply be installed onto any computer. The software interface has been created to mimic an actual remote control unit with important buttons such as, for example, for choosing the operating mode, specifically represented. Such functionality is particularly important for the education sector where the projector is generally used by multiple people and a single remote control unit is otherwise too limited. Moreover it tends to get lost. It also means that the annoying climb over tables and chairs to switch a fixed installation-projector on or off is now no longer required.
Outstanding options for centralised network control and monitoring via the RJ45 LAN connection are additionally enabled by the PC Control Utility Pro 4 software. The NEC NP500WS and NEC NP600S have been equipped with a function allowing the programming of user-defined operating times so as to automatically switch them on and off. This can be set using the projector itself or via software-control over the entire network. Automatic error messages are also sent to the system administrator when a fault occurs indicating the source of the error, which makes maintenance of the devices significantly easier. The PC Control Utility Pro 4 software can be downloaded free of charge from the NEC homepage.
http://en.sgsm.info/2009/03/23/nec-n...e-projections/
NEC NP500WS and NEC NP600S: Short-distance projections scutt NEC 1 04-07-2009 03:17
nec E122 and nec 808 The Razor NEC 0 04-17-2008 13:45
nec crassy and and spunlock unlocker unlocked only one network for my nec e228 syms NEC 2 02-26-2008 17:13
Nec E228 And Nec 616 Language Change??? Nicko_12345 NEC 0 10-25-2004 12:14
Page generated in 0.19062 seconds with 11 queries
