03-19-2007, 08:46 | #2 (permalink) |
Junior Member Join Date: Apr 2006
Member: 258783 Status: Offline Thanks Meter: 0 | I also have the same problem so I will write here. I got the phone NEC e122 with no charger, as I see it has a samsung connector, so I need charger pinout, because to find original charger in lithuania is nearly impossible. Maybe a samsung charger could be used there, as the connectors are the same, only i dont know about pinouts, maybe someone can help |
03-19-2007, 09:08 | #3 (permalink) |
Member: 258783 Status: Offline Thanks Meter: 0 | I found this, but thats all? as i see in my samsung charger there few more pinouts and as in the pinout of the most samsung phones http://pinouts.ru/CellularPhones-P-W...0_pinout.shtml there are two more 12 7 CHARGER_OK power on/off and charging control 13 6 JIG_REC power on/off scheme control and 7 12 REC01 power on/off scheme input As in my samsung charger there only for contacts from the charger connector, +- and few more. are they all needed to charge the phone? NEC E122 18 pin Samsung cellphone special connector at the cellular phone (keyboard up) 1,2 GND 9 Rx 10 Tx i found it there: http://pinouts.ru/CellularPhones-A-N...2_pinout.shtml but I dont know if thats all I need to make a charger for e122 or maybe I could simply use samsung charger? |
Charger Connector for Nokia N78 Phone - Original | IPMART | ipmart WebShop | 0 | 12-13-2008 07:25 |
Charger Connector for SE Z600 Phone - Original | IPMART | ipmart WebShop | 0 | 11-25-2008 08:50 |
Charger connector for K6xx ? | gsavv723 | Wanted Products | 0 | 12-25-2006 12:34 |
I need pinout charger for sagem Myc-5w | ejsr | ARM9 BASED M62 / M62+ | 1 | 03-12-2005 14:23 |
Need pinout t191 connector under battery for JTAG | MaxiGroup | Motorola ODM | 5 | 08-15-2003 10:36 |
