Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > NEC
Old 05-07-2004, 22:07   #1 (permalink)
Registered User
Member: 8527
Thanks Meter: 11
Problem unlocking NEC e606...
I have a problem with unlocking an NEC e606...
I tried on different computers with NEC EXXX WCDMA unlocker. I can read the flash ID, but when I press the Unlock ME button I get an error saying "****, something wrong".
What can I do to unlock it??? The trick with the codes don't work...
Old 05-07-2004, 22:51   #2 (permalink)
Medusa Lancer's Avatar
Member: 52360
Sonork: 100.1611553
Thanks Meter: 42
hi
the soft wcda work 1000% contact via icq for help
Old 05-07-2004, 23:59   #3 (permalink)
silvester's Avatar
Member: 6845
Thanks Meter: 30
Use 3.10 and even if you got this error,phone is unlocked.
Regards
Old 05-23-2004, 07:45   #4 (permalink)
Irinel's Avatar
Member: 4201
Thanks Meter: 6
Use new version,will work.
Best regards,
Irinel
Old 07-24-2004, 12:24   #5 (permalink)
Member: 74591
Nec e606 unlock problem
Hi folks!
I unlock my nec e606 with wcdma and testpoints, so nothing specilal, but when i use my vodafone sim card from Portugal, the phone acept the card but only the 2G function are available, i cannot make video call and i have 3G coverage, if i use a Three sim card UK (expired), the phone don't have coverage but the 3G function are available for example the bluetooth option already work.
if i press *#7320# the phone send this message:
USIMlocked to network
00101
23420
45404
23594
i think the phone still locked... only make a bypass in startup usim card check.
So any help is welcome!
Best Regards.
Old 08-25-2004, 19:00   #6 (permalink)
krusty.spritz's Avatar
Member: 14045
search your computer for c55.log and delete it, then it will see the phone.
Old 08-25-2004, 20:51   #7 (permalink)
=CostyGSM='s Avatar
Member: 46387
Thanks Meter: 139
Wink
Originally Posted by bibi019
hello
i have try to unlock my nec e606 with the test point ''cable t191'' wcdma software but it dosn't work the software stay at scanning and nothing after please hope me
thanks [email protected]
soft work1conect the corect rx ,tx and gsnt to pcb and will work,this soft is only for network code ,you can get message: "something is wronf"if the phone is already unlocked.
Old 10-15-2004, 21:11   #8 (permalink)
Member: 9418
Thanks Meter: 15
I have the same problem as HyperBolico
And my phone don't even make an emergency call now =(
Even without SIM =(((
Old 12-29-2004, 14:26   #9 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
I have here two E606 whit same problem always **** something wrong..........who have solved problem?
Old 12-29-2004, 14:31   #10 (permalink)
Member: 14045
itcould be any number of things.....first check soldering
then swap tx and rx leads.......also check coms speed
alsocheck that the fone didnt unlock the first time as this message has shown when a slight comms error happens.......but unlocked ok....just check
Old 12-29-2004, 19:08   #11 (permalink)
Member: 3381
Thanks Meter: 1,171
When show **** something wrong the phone are unlocked sorry.
Old 12-30-2004, 01:44   #12 (permalink)
Member: 101662
Originally Posted by HyperBolico
Hi folks!
00101
23420
45404
23594
Best Regards.
the above numbers are operator id's
How unlock NEC e606 Rakun NEC 98 12-02-2008 14:52
I need unlock NEC e606 Elian NEC 5 09-05-2004 21:03
Need unlock Nec e606 aliwali NEC 8 09-29-2003 07:30
Can anyone unlock NEC e606 remotely? .:: unlocker ::. Phone Unlocking Codes & Maps 0 09-26-2003 12:08
UNLOCK NEC e606 NELIX Phone Unlocking Codes & Maps 0 08-27-2003 14:25
Page generated in 0.19113 seconds with 9 queries
